A drinking straw with a bit of ATF. Cap the bottom with your finger and place the tip at the bushing side of the fan, then dribble the ATF. Spin the blades a goodly amount so that it works its way through. The fan hook up is on the firewall. You can unplug the pigtail and use small gauge wire hooked to the battery with alligator clip at the ends. There are four posts. Pick one to be hot and try the other three with the negative lead. Fan is three speed, so when you find one that works, you know you have at least one side hot. See if you can get the fan to move in all three speeds.
The fan is not useful for heating. It is only a defog fan. Most of the heat for the cabin is from having fresh air flow over the heat exchanger at speed. One of the levers closes a flap so the cold air does not come into the cabin while the hot air is routed to the dash vents.
Shop time to replace the fan (which is hung at the factory and the car built around it) is 12-15 hours. The fan is sort of NLA, but retails in the $700 range. Shop rates are $95-180/hr. A few people choose not to remove the interior of the car, dash and all, but go through the fresh air vent, cut out the metal shield and pull the fan from the outside. Much quicker, but no less complex.
