capping oil pressure guage - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-23-2015, 05:02 PM Thread Starter
singsingsing's Avatar
Date registered: Apr 2015
Vehicle: 1970 - 220D
Quoted: 2 Post(s)
Newbe 220D guy again (singsingsing) - the instrument cluster has to come out so that the speedometer and clock can get fixed. My shop guy has a small facility, so leaving the car there while the repair get done isn't going to be possible.
Is there a way to cap the oil line so I can drive 10 miles home without a disaster?
singsingsing is offline
post #2 of 6 (permalink) Old 04-23-2015, 05:35 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1805 Post(s)
I don't recommend this, but I had a leak in my oil sender line (due to rodents) and to stop it, I put a vice grip on the oil sender line.
It would be better if you could find a correct size nut or bolt to put in there.
Glad you realized this before starting the car!
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 6 (permalink) Old 04-24-2015, 08:04 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
take a piece of quality fuel hose that will slip over the fitting , double hose clamp it at the plastic line after the fitting , put a bolt at the open hand and also double clamp it , you can drive for ever like that .
agillot is offline
post #4 of 6 (permalink) Old 04-24-2015, 12:51 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1640 Post(s)
I seem to recall having this challenge around twenty years ago, and I just removed the oil pressure gauge section from the cluster, and then screwed it back onto the oil line. It's just a mechanical bourdon tube, so that won't be part of the speedo head or clock repair. Btw, have you looked here in the archives about how to repair both items? I suspect that both have been discussed.
Zeitgeist is offline
post #5 of 6 (permalink) Old 04-24-2015, 01:06 PM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
When I first started working on my car, I did start the engine with a disconnected oil pressure sending tube staring me in the face. The results of this created a funny but upset situation.
Luna Gaudi's 72 250 is offline
post #6 of 6 (permalink) Old 04-25-2015, 05:45 AM
Date registered: Aug 2009
Quoted: 72 Post(s)
Thumbs up
Best solution to the problem.
No worries about crushing the line, leaking clamps, etc.
Mike D is online now
