W115 rear seat removal? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-23-2015, 02:11 PM Thread Starter
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
Hi, the rear seat of my W115 doesn't wanna come out. I'm probably doing it wrong but I've tried and tried and nothing. The bottom part is out already but the back part of the seat is the one stuck. Any info on how to remove it?
Kaelor is offline
post #2 of 6 (permalink) Old 04-23-2015, 02:16 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1465 Post(s)
It's been a very long time, but on the 110 models, there are fasteners on the inside lower fender hump areas, and on the trunk side upper bulkhead area--four total. From my hazy memory, the 115 may drop into an upper lip on the package tray and then use two lower bolts
Zeitgeist is offline
post #3 of 6 (permalink) Old 04-23-2015, 02:27 PM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
So I should check the trunk and maybe the fender too? It makes sense, no wonder I can't remove it. Similar stuff happened to me with the headlights lol.
Kaelor is offline
post #4 of 6 (permalink) Old 07-17-2015, 04:27 PM
Date registered: Jul 2015
Kaelor: Did you ever have any luck in getting the seat back out?
So far I've removed the nuts at the base of the seat back (pic 1), and the two that go through to the trunk area (pic 2). Are there any more that I'm missing? Do I just need to pull it in a certain way to get the seat back out?
Name:	1 - rear seat back base.jpg
ID:	1535577   Click image for larger version
Name:	2 - trunk.jpg
schickm is offline
post #5 of 6 (permalink) Old 07-17-2015, 07:20 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1647 Post(s)
I believe it's just four nuts for the back seat. I always pull the bottom of the back out first.
You should be clear to pull.
My signature:
Click for list of my 33 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #6 of 6 (permalink) Old 07-21-2015, 10:34 AM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
Did you removed the seat belts? I think they link to the seat too, can't remember correctly but I did took out the seat belt bolts for the back. Try pushing and lifting the back seat at the same time.
Kaelor is offline
