oil pan heater - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-12-2015, 12:59 PM Thread Starter
singsingsing's Avatar
Date registered: Apr 2015
Vehicle: 1970 - 220D
Quoted: 2 Post(s)
oil pan heater
Before this newbie gets into some expensive stuff, let's eliminate the oil temp as a cause of poor starts. Who knows the best oil pan heater for a 1970 220D, and where to get one?
singsingsing is offline
post #2 of 3 (permalink) Old 04-12-2015, 01:08 PM
LostInTime's Avatar
Date registered: Oct 2013
Vehicle: 07 E350, 80 240D 4 speed, 90 300SE, 87 260E, 87 190E 2.3-16 5 speed.
Quoted: 626 Post(s)
I have used similar to this on and off for over 30 years.
It is a bit of a pain getting down on the ground to install and remove, but it works fine. Only requirement is a steel oil pan.
http://www.amazon.com/Kats-1153-Handi-Heat-Magnetic-Heater/dp/B000BOABS6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1428869223&sr=1-1&keywords=oil+pan+heater+magnetic
LostInTime is offline
post #3 of 3 (permalink) Old 04-12-2015, 05:19 PM
redghost's Avatar
Date registered: Oct 2012
Vehicle: 1972 220 D, 1974 450SL, 1995 E300D 2002 S430, 1976 300D, 1986 SDL, 1982 SD
Quoted: 288 Post(s)
Why not the standard MB block heater? These things are about 500watt and take an hour or so to warm the whole block. Using Mobil 1 will allow you to get better cold starts as well.
Clay
74 450SL - Froggy
'02 s320 - Victor
'86 300SDL - Polei
'82 300SD - Allen
Retired cars
'76 300D - Voldemort
'95 E300D - Cleo
'72 220D - Gump
'87 300SDL - POS SDL
92 300SE - #1 boys ride
redghost is offline
