220D start problem - Page 3 - Mercedes-Benz Forum
post #21 of 33 (permalink) Old 04-17-2015, 11:18 AM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
Originally Posted by Zeitgeist View Post
Adjust the valves first, though
Actually I would check compression before and after, that way you know if it had an effect on the situation. This is to resolve a starting issue isn't it? It seems that was what the thread was about.
Bill A is offline
post #22 of 33 (permalink) Old 04-17-2015, 11:24 AM
Date registered: Aug 2009
Quoted: 73 Post(s)
You can kill two birds with one stone if you are set on replacing the glow plugs. There is an adapter which fits into the glow plug socket. After you pull the plugs you can check the compression readings.
You must use a compression gauge made for diesel engines. The pressure developed in a good diesel engine will blow the face right off one of the "girly" gauges made for gasoline engines.
Bill A likes this.
Mike D is offline
post #23 of 33 (permalink) Old 04-17-2015, 11:52 AM
Bill A's Avatar
Quoted: 27 Post(s)
I always used the AutoMeter recording meter. Stapled the card to the repair order when finished, removes all speculation if something is out of order. When doing a job like this I as well pulled the injectors and tested their pressures and patterns and corrected what was off. If all was in order with the nozzles I did the pump timing so i knew how things were going to work out. I ran a dyno for many years and basically did performance issues.
Bill A is offline
post #24 of 33 (permalink) Old 04-17-2015, 12:00 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1647 Post(s)
yeah, I have one of those:
Bill A and GreenT like this.
Zeitgeist is offline
post #25 of 33 (permalink) Old 04-18-2015, 06:13 AM Thread Starter
singsingsing's Avatar
Date registered: Apr 2015
Vehicle: 1970 - 220D
Quoted: 2 Post(s)
Yo Zeitgeist, and everyone else with advice for this newbie. Many thanks for the wise council.
Here's the skinny on the 220D start problem. I'm the idiot. My only MB experience prior to this 220D was a brief ownership of a 83 240D awhile back. All the glow plug stuff was handled by the car itself. "Gorilla knob" and manually HOLDING IT WITH PRESSURE AGAINST AN INVISIBLE STARTER SPRING while the glow plugs get hot was not in my little brain. After a couple of painful failures trying to start this old soldier without any heated glow plugs. I finally got an explanation from the previous owner (who thought I would naturally know this stuff) guess what - it started in 30+ degree temp on the first pull, no smoke !!! Almost as good as sex. And by the way, compression is over 300 on all. I am thinking though of going to the pencil type lugs at some point.
I am sure glas you EXPERTS are around for people like me.
GreenT likes this.
singsingsing is offline
post #26 of 33 (permalink) Old 04-18-2015, 06:42 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 518 Post(s)
DOH, if all else fails, read the instructions!
GreenT likes this.
rumb is online now
post #27 of 33 (permalink) Old 04-18-2015, 09:05 AM
GreenT's Avatar
Date registered: Mar 2013
Vehicle: 1995 S500, 1990 420SEL
Quoted: 7075 Post(s)
Getting old sucks.
GreenT is offline
post #28 of 33 (permalink) Old 04-19-2015, 05:27 AM
Quoted: 73 Post(s)
Originally Posted by GreenT View Post
Getting old sucks.
Beats the alternative.
Mike D is offline
post #29 of 33 (permalink) Old 04-19-2015, 11:44 AM
GreenT's Avatar
Still sucks.
GreenT is offline
post #30 of 33 (permalink) Old 04-20-2015, 06:17 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
first thing a valve adjustment . a older worn engine will be hard starting when cold .
agillot is offline
