1963 220s fuel pump - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 03-11-2015, 10:17 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
Let us know how it turns out.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #12 of 16 (permalink) Old 03-11-2015, 10:22 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
Odd, I thought I replied to this one ... maybe I replied to the related one.
Take a look at Summit Racing. They have real-person phone support as well as internet chat support. If you tell them what kind of fuel pressure and volume you need from your pump, they can match you to a correct electric pump. I'd recommend asking about fittings and such to mate it to your fuel lines, and any mounting hardware to make it all easier.
Grubeguy is offline
post #13 of 16 (permalink) Old 03-12-2015, 05:24 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
VW beetle and early MB
In an emergency quite a bit of parts from the vw beetle can be used ; Bosch rotors,points ,fuses,ignition cables fuel pump diaphragm .
The Bosch fuel- triggerpoints in D Jetronic fueling is used in w109 3.5 and other 116 engines cost a $250, so VW injection points help.
adler is offline
post #14 of 16 (permalink) Old 03-12-2015, 06:10 AM Thread Starter
Date registered: Dec 2013
Vehicle: 1963 220S, 2002 S55 AMG, 1976 450SL, 2005 S500
Thanks for all the input
belaire61 is offline
post #15 of 16 (permalink) Old 03-12-2015, 08:22 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
you could use the 115 090 01 50 , but you must cut off the out line and replace the fitting with a hose / 2 clamps , or better a inline fuel filter .also you MUST USE the spacer between pump and block , number 110 091 02 81
agillot is offline
post #16 of 16 (permalink) Old 03-12-2015, 09:14 AM
Grubeguy's Avatar
Quoted: 102 Post(s)
Bosch supplied that same fuel pump (and the d-jetronic injection system) for a ton of other applications, including Audis, Porsches, VWs, et al. Is there a rebuild kit available for this pump?
Grubeguy is offline
