Coolant loss - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-08-2015, 03:50 PM Thread Starter
Date registered: Mar 2015
Vehicle: 1992 300E
Coolant loss
My 1992 300E has started using coolant. Some seems to be coming out of the exhaust pipe--don't notice any in oil, but uses a cup or so in a 20 mile round trip. Will this ruin the engine if I keep driving it, replacing coolant as it is used up? Is a head gasket replacement the only solution. Coolant reservoir has been replaced as have some of the lines. Any suggestions???
Hazelinohio is offline
post #2 of 7 (permalink) Old 03-08-2015, 06:47 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 444 Post(s)
How many miles on the engine? this engine will at some time in it's life need a head gasket. very common they develop leaks. search the forum for info on this.
As for driving with a big internal leak, probably not a good idea. Could easily get worse and blow the gasket.
Do you have white smoke out of tailpipe?
rumb is online now
post #3 of 7 (permalink) Old 03-09-2015, 10:39 AM Thread Starter
Vehicle: 1992 300E
300e coolant problem
There is white smoke out of the tailpipe and coolant does come out a bit when the car is parked. The car has almost 200,000 miles on it, body is in great shape. It does use oil, has since purchase in 1995, but there has been an oil leak lately around the head gasket. Looks like I had better check to see how much a head gasket will cost. There goes IRS refund plus!!! I love the car and hate to get rid of it.
post #4 of 7 (permalink) Old 03-09-2015, 12:03 PM
rumb's Avatar
Quoted: 444 Post(s)
The external oil leak is a sign also. I replaced the head gasket on my 300SE 2 years ago. I spent about $650 on parts, as I replaced pretty much every piece of rubber that is involved. plus full tune up, water pump, new head bolts, valve stem seals, etc.
rumb is online now
post #5 of 7 (permalink) Old 03-09-2015, 01:55 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Youch, sorry to hear of your problems. If you hadn't mentioned white smoke out the tail pipe, I'd have suggested checking the radiator cap. I had a slow loss issue which was cured with a replaced cap...
Grubeguy is offline
post #6 of 7 (permalink) Old 03-09-2015, 05:39 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
How does your oil look on the dipstick? If it's milky brown I suggest you change the head gasket before you do more damage.
Will
Baybear is offline
post #7 of 7 (permalink) Old 03-10-2015, 05:24 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 88 Post(s)
Your engine is circling the drain - fix it immediately or the repair cost will jump out of reach when seizure occurs. Begin analysis by pulling the head and inspecting the head gasket.
ejboyd5 is offline
