New owner 1972 250c - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 02-17-2015, 06:24 PM Thread Starter
Date registered: Feb 2015
anyone familiar with refinishing wood trim? the lacquer coating has deteriorated. I will refinish it later but first i have to learn how to do it.
Here is the first aid kit in its pocket.
solidglobe is offline
post #12 of 15 (permalink) Old 02-18-2015, 05:39 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 511 Post(s)
search the forum, there are plenty of how to do's.
solidglobe likes this.
rumb is offline
post #13 of 15 (permalink) Old 02-18-2015, 11:09 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 104 Post(s)
I second what rumb said. I put out a lengthy one myself a few years ago, as have some other folks.
That coating is just about like clear plastic - it's tough. When I redid all my wood, I used paint remover, and even then it took a while to come up. Recommend NOT using anything more stout than a plastic scraper though, or you risk scraping the wood. I used marine grade stain and sealant, after reading how less stout stuff (indoor use only?) would deteriorate much much more swiftly in the more extreme conditions of a car interior.
Grubeguy is offline
post #14 of 15 (permalink) Old 02-18-2015, 11:14 AM Thread Starter
Thanks, i searched google. and read about the process. but found only what was used.. read about polyurethane lacquer, and clear enamel.
i will definitely look for marine grade.most of the clear topcoat has flaked off.. i will just go over with a light sand paper and stain then clear coat.
post #15 of 15 (permalink) Old 02-18-2015, 12:43 PM
Date registered: Dec 2006
Don't sand it. The exterior is a paper-thin veneer and you'll go through it in no time. 0000-grade steel wool is a better bet.
Here's a good write up (though a slightly different model):
W108 Wood Refinishing | JaimeKop.com
jmela is offline
