alternator - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-01-2015, 08:34 PM Thread Starter
Date registered: Jan 2014
Vehicle: 1975 280s
alternator
I need to replace the alternator on my 75 280s. On line replacement costs run $75 - $200. Any suggestions where to look
Thanks
mercymercy is offline
post #2 of 11 (permalink) Old 02-01-2015, 09:36 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1677 Post(s)
alternator
280s ?
Is that an m130 with zenith carbs?
Autohausaz carries them, but in researching one for my m130 w114, I realized that the alternators on the 4.5 m117 450sl cars are the same config, but just a little higher amps. I happen to have two of those (used) in my garage. So no need for me to go purchasing for my m130 w114.
Start with autohausaz and take note of the part numbers. There are likely tons of compatible alternators you could pick up.
Edit: oops... Ok. I see it's a 1975. That's a w116, correct? Is there really suck a thing as a 280s? Wouldn't it be a m110? And did
They make them carbed? 280s, not 280se? Edit: yep. Wow. Sure is. A solex carb you say here: http://www.benzworld.org/forums/8755433-post.html
Sorry. I'm not sure if autohausaz comments will apply.
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 11 (permalink) Old 02-01-2015, 10:50 PM Thread Starter
Vehicle: 1975 280s
Yes it's a 75-280s-116-110 solex and autohaus does carry the them.Thanks for reminding me.
post #4 of 11 (permalink) Old 02-02-2015, 07:46 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
Are you sure you need the new alt? Sometime in the mid '70's MB alternators started having the brushes built into the voltage regulator which was attached to the back of the alternator. If you are lucky you have one of these and you can change brushes and regulator on your back under the car only having to remove 2 screws.
Frank Flynn
'73 220D
'88 300SEL
'91 300TE
frankflynn is offline
post #5 of 11 (permalink) Old 02-02-2015, 09:06 PM Thread Starter
Vehicle: 1975 280s
I think I can see the voltage regulator attached to the alternator. I'll crawl under to verify.
Thanks for the info
post #6 of 11 (permalink) Old 02-03-2015, 09:00 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
before you do that , when you turn the key on , does the battery light comes on , i ll bet it does not , if that is the case , you need new brushes on the voltage regulator .remove it [ 2 screws ] and you will see one worn brush to the point it looks dull compered to the other .[ very common problem ]
agillot is offline
post #7 of 11 (permalink) Old 02-03-2015, 12:47 PM Thread Starter
Vehicle: 1975 280s
The battery light comes on when I turn the key and goes off when it start the engine. Here's what I've done so far testing the alternator... Bought new battery. Put multimeter on battery with motor off. It tested 12.7v. Then started engine, turned on lights,blower,radio ext. Meter showed it dropped down to 11.9v Revving the engine didn't make much diff. I got one quote of $750 to replace alternator and belt. Seems stupid high
post #8 of 11 (permalink) Old 02-03-2015, 04:09 PM
Premium Member
Quoted: 59 Post(s)
Premium Member
make sure belts are tight , and replace the volt regulator at rear of alternator [ 2 screws ] , also does the battery lite glows with engine running and load on ???? part number 002 154 58 06 , do a GOOGLE on that number . should be cheap .
agillot is offline
post #9 of 11 (permalink) Old 02-03-2015, 04:57 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Agillot. what charging voltage should he see after a regulator change on this model alternator?
adler is offline
post #10 of 11 (permalink) Old 02-03-2015, 05:42 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
I think around 13.8 plus or minus. Agillot is master mechanic and will chime in
Will
Baybear is offline
