w108 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 01-22-2015, 03:36 AM Thread Starter
Date registered: Feb 2011
Vehicle: 1978 450 slc
Quoted: 9 Post(s)
w108
i live in asia and noticed that all w108 types are very high on the backside (see attachment) what makes the wheels going in,i dont see this with the europe and america model.
any one know what the reason is and how to lower them?
ID:	1292369   Click image for larger version
ID:	1292377   Click image for larger version
nongnoek is offline
post #2 of 9 (permalink) Old 01-22-2015, 05:25 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 510 Post(s)
Interesting phenomenon. They must all have too strong of spring over the rear axle.
rumb is offline
post #3 of 9 (permalink) Old 01-22-2015, 01:03 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
My $.02 -
108s had an option "Spring suspension w/ground clearance increased (for countries having bad roads)". Cars sold in Asia probably had this option. This package may have had stiffer springs and/or a hydraulic compensator that raised the body.
Also cars equipped with the hydraulic compensator (expensive) may have had it replaced with a spring at some point.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #4 of 9 (permalink) Old 01-22-2015, 06:57 PM Thread Starter
Quoted: 9 Post(s)
thanks a lot,never hear about this it make sense my complements for your knowledge, it looks very ugly so i think i will cut the springs a little to get it strait.
nongnoek is offline
post #5 of 9 (permalink) Old 01-22-2015, 07:23 PM
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
You will not have to cut very much. some guys here put thinner rubber shims at the ends of the spring to help lower the back.
Let us know how you get on.
Cheers John.
wroding is offline
post #6 of 9 (permalink) Old 01-23-2015, 02:04 AM Thread Starter
Quoted: 9 Post(s)
yes i will try that first,thanks i will let you know the result!
nongnoek is offline
post #7 of 9 (permalink) Old 01-23-2015, 05:28 AM
rumb's Avatar
Quoted: 510 Post(s)
It is just one spring, not "springs" above the center of axle.
rumb is offline
post #8 of 9 (permalink) Old 01-23-2015, 07:34 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the car did not come that way when new , the 2 main springs have a adjustable plate at bottom , there are 3 positions , but i would first look at the center spring , it has a lot of action on the car height .the easy way would be to have the rear wheels on floating tables , and then use a torch to heat up one coil , the car will then drop some .[ watch out , the gas tank is near ] .
agillot is offline
post #9 of 9 (permalink) Old 01-28-2015, 04:58 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Hmm... Heating the compensating spring to lower the suspension ,not aware it could be done on car.
adler is offline
