240-300 engine swap - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-02-2015, 07:38 AM Thread Starter
Date registered: Jan 2015
240-300 engine swap
I have a 1975 240D, 4 speed, 4 cyl that I would like to pull the tired engine out, and install a 5 cyl from a 1976 300d automatic. Both are non turbo of course. I am concerned that I will run into a flywheel problem or some other issue. I want to keep the 4 speed in the 75, so will the flywheel from the 4 cyl bolt up to the 5 cyl? That`s my biggest concern. I guess I could use the automatic, but I don`t want to. Thanks in advance
480VAC is offline
post #2 of 2 (permalink) Old 01-02-2015, 11:00 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1574 Post(s)
Is it possible that your trans is used with the 300 motor? If so, you would expect no problems. Right?
Get the trans part number:
- either use your VIN and the EPC, or
- get the number from the trans itself.
Take the part number to the EPC to see what all models it was used with.
For all you know, it is a trans that was used with the 300 anyway.
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
