Trouble starting my W114 after a time left alone - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 01-18-2015, 04:24 AM Thread Starter
Date registered: May 2010
Vehicle: 1971 250CE (W114)
One more thing - my brother had to move the car last week and pushed it back 6-7m and then forward the same distance. When I came back it had been left in gear so I presume it was also moved in gear. I know automatics aren't supposed to be pushed - would this have damaged it?
Thanks
MacDanger is offline
post #12 of 18 (permalink) Old 01-18-2015, 05:35 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
That small of distance and slowly pushing will cause no damage.
Check you shifter linkage bushings, they may all be bad or gone.
With car safely supported, watch under car as shifter is moved and see if lever on side transmission actually moves.
Good to hear car is now running again.
rumb is offline
post #13 of 18 (permalink) Old 01-19-2015, 12:42 AM Thread Starter
Thanks rumb - from what you say it'll be easy to enough to see whether there's something moving when the gearstick is moved anyway.
Are the parts for the gearbox something I'll be able to get from a motor factors? Or would these be specialist parts I'd need to order?
post #14 of 18 (permalink) Old 01-19-2015, 11:17 AM
rumb's Avatar
Quoted: 488 Post(s)
Well now your just talking a foreign language to me..
On this side of the pond any online parts supplier would have them. or the dealer, they are inexpensive.
Here is the tool I made to install them
http://www.benzworld.org/forums/vint...hing-tool.html
rumb is offline
post #15 of 18 (permalink) Old 01-23-2015, 10:52 AM
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 103 Post(s)
I doubt your brother would be able to push the car by hand if it were in gear. Are you certain it is in park? If your shifter bushings are perished the car may not be going fully into gear.
dgosh28 is offline
post #16 of 18 (permalink) Old 01-28-2015, 04:54 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Would this engine be a D jetronic fuel system or early CIS one?
adler is offline
post #17 of 18 (permalink) Old 01-28-2015, 05:13 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
buy a spray can of starting fluid , if it does nothing with that [ clean spark plugs ] , then you have no spark .
agillot is offline
post #18 of 18 (permalink) Old 01-28-2015, 05:52 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1719 Post(s)
I can't imagine it would be CIS (k-jet). I know 72-75/76 w107 were d-jet and then k-jet for 76+. So it's very very unlikely that the w114 could be k-jet.
There was an earlier injection (don't know the name) that is apparently similar to diesel injection with an injection pump or something like that. I never had one, but I think that's the type of injection that a 1971 6-cylinder would have.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
