55 amp alternator to replace 35 amp ? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-28-2014, 06:37 AM Thread Starter
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1716 Post(s)
The battery isn't charging in my 1972 250c which apparently should have a 35 amp alternator, just like my 1970 250c parts car. I happen to have two 55 amp alternators from 1972 350sl 4.5 cars sitting around. All of these used alternator options seem like they would possibly work, and the 35 amp would be the safer bet probably. However, I wonder if the 55 amp would be better to charge a larger battery and not cause any wiring problems. Just curious of the thoughts of the smarter people.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #2 of 5 (permalink) Old 12-28-2014, 07:46 AM Thread Starter
Fonzi's Avatar
Oops. Forgot the pics from autohausaz
55 amp alternator to replace 35 amp ?-imageuploadedbyautoguide1419781541.224496.jpg
55 amp alternator to replace 35 amp ?-imageuploadedbyautoguide1419781556.070004.jpg
55 amp alternator to replace 35 amp ?-imageuploadedbyautoguide1419781567.120047.jpg
My signature:
Fonzi is offline
post #3 of 5 (permalink) Old 12-28-2014, 07:59 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
Have you determined that the alternator is bad? I'm not very knowledgeable on charging systems but I think that you can increase the alternator power and that as long as the voltage regulator is happy with it then there isn't a problem. On my 85 300TD it was a matter of replacing the diode on the back of the alternator, which I don't remember how I did.
Scoot is offline
post #4 of 5 (permalink) Old 12-28-2014, 08:24 AM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 43 Post(s)
You should be fine. I replaced my 35 amp alternator in my 1971 280SL with the 55 amp. Direct fit, same connector and as long as your voltage regulator is working not problems with overcharging.
Will
Baybear is offline
post #5 of 5 (permalink) Old 12-28-2014, 10:07 AM Thread Starter
Fonzi's Avatar
I actually have not. I should do some tests, and will look at the wiring diagrams next.
When I realized that the 4.5 m117 starter is the same as the m130, I realized I should take a look at whether the alternators I have laying around loose might be easier or better to use than the one in the parts car.
I can probably take the wiring out of the 1970 parts car pretty easily. So I will probably give this a try (after looking at the wiring diagram). Thank you!
Will
Awesome. I found some general info on the net that seemed to say the same. So the only info to determine would be if it's a direct bolt-on replacement as it appears. Now you've even confirmed this for me. Thank you!!
My signature:
Fonzi is offline
