1981 380SL Engine restoration - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-14-2014, 01:09 PM Thread Starter
Date registered: Dec 2014
Vehicle: 2001 S500, 1981 380SL
Quoted: 13 Post(s)
Hi,
I'm new here, so I hope I'm posting in the correct forum. I just bought a very neglected '81 380SL and I'm looking for suggestions on what to do to make the very oxidized parts on the engine look good.
Specifically, I'm looking for the best way to clean/remove the oxidation, from the air cleaner/valve covers etc, also what to do with them once clean, e.g. paint, if so what colors.
Does anyone have a good picture of an original or restored V-8 of that era?
Thanks in advance.
Perry
fischp is offline
post #2 of 6 (permalink) Old 12-14-2014, 04:24 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
take a close look at this car before you start , 81 could still have a single row timing chain , also if it is high mileage , poorly maintain , dont start .you can get a descent 380 sl around 6 k .
agillot is offline
post #3 of 6 (permalink) Old 12-15-2014, 06:40 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
As stated above, the first thing to do is check to see if it is a single or double row timing chain car. If it is a single row, it can be converted to double chain by a competent mechanic. The single row are prone to failure and that is a bad thing.
That said, the valve covers were not painted or polished, they were just aluminum. If they look bad, I would invest the $12 for new valve cover gaskets. Pull the valve covers and clean them using steel wool first then some metal polish until they shine like you want them to. It is not hard and can be done in a few hours of rubbing. They will shine as much as you are willing to polish them. While you have them off, look at the timing chain.
Same with your air cleaner.
TZ_280SEL is offline
post #4 of 6 (permalink) Old 12-15-2014, 08:54 AM Thread Starter
Quoted: 13 Post(s)
Thanks for the info! Very helpful, this is my first MB restoration. I'll pull the covers and look for the timing chain(s), I assume there's a kit to upgrade me from single to dual if needed.
I'll also invest in a box of steel wool and some good polish.
P
fischp is offline
post #5 of 6 (permalink) Old 12-15-2014, 11:46 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 480 Post(s)
rumb is offline
post #6 of 6 (permalink) Old 12-19-2014, 10:33 AM
Earl.Allen's Avatar
Date registered: Mar 2014
Vehicle: '84 300D, '82 240D, '75 450SL, '93 300CE
Quoted: 25 Post(s)
Polishing power tools are your friend...
Earl F. Allen
1975 450SL 197K (for sale)
1982 240D 234K (for sale, unfortunately)
1984 300D 225K
1993 300 CE (wife's new driver)
2004 VW Jetta TDI (my new driver)
Earl.Allen is offline
