help with dash lights - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-11-2014, 12:14 PM Thread Starter
Date registered: Dec 2014
Just bought a 82 300sd turbo diesel, And this is my first car. My dads a mechanic but I want to fix this car up my self. i fixed the speakers/radio, alarm, and fuel gauge already, but for some reason i can't get the lights where the speedometer and fuel gauge are located, to work. Do you think this could just be a simple needing to change the bulb? Thanks!
Kalike is offline
post #2 of 8 (permalink) Old 12-11-2014, 12:34 PM
Date registered: Sep 2014
Vehicle: 1975 Mercedes 450 SEL
Quoted: 14 Post(s)
if some of Instrument Cluster panel lights work the the rheostat dimmer should be ok can you adjust the light intensity ? if so that unit is ok
Anyway yes if some lights work it could be just some of the light bulbs . You might hit a salvage yard and grab all the bulbs and I would also get the Light dimmer for the dash lights as they often go out in time
aluminum is offline
post #3 of 8 (permalink) Old 12-12-2014, 01:03 AM
TCC&D's Avatar
Date registered: Nov 2010
Vehicle: 2010 GL 350 BluTEC; 1967 250SE Sedan (Euro).
I "highly recommend" you watch the YOUTUBE video on dash lights put out by mercedessource.com.
In fact, watch all his videos and you'll learn a lot about your new car.
TCC&D is offline
post #4 of 8 (permalink) Old 12-12-2014, 09:45 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
rotate the small knob at left on cluster to see , if nothing happen , the rheostat is bad [ common ] , just remove it , and solder a wire across it and put it back .
agillot is offline
post #5 of 8 (permalink) Old 12-17-2014, 02:09 AM Thread Starter
Awesome thanks!! I'll take a look at these things.
Kalike is offline
post #6 of 8 (permalink) Old 12-17-2014, 02:10 AM Thread Starter
I actually have watch some of his videos. That's how i got my radio to work again!
Kalike is offline
post #7 of 8 (permalink) Old 12-17-2014, 05:21 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
The bulbs aren't unobtanium - you can find them at Autozone, Napa, etc.
Something you might consider is the color of the things. Years ago, I had my speedometer replaced and elected to put blue sleeves across the bulbs, all of them, including the one in the gear selector. Instead of a plain white light, I had a soft blue. You can find those in multiple colors, and they're available at Amazon, eBay, etc.
Grubeguy is offline
post #8 of 8 (permalink) Old 12-30-2014, 08:13 PM
Date registered: Sep 2013
Vehicle: 1978 W123 240D
I replaced a good number of my bulbs with LED's, but found on someof them, weird stuff started happening so put regular bulbs back in. While you have your dash out would ba a good time to look over your odometer. mine was non-functional so replaced it while wiring across my rheostat.
majorrich is offline
