Hopefully not a major mistake on my 450SL - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-01-2014, 08:52 PM Thread Starter
Date registered: Dec 2014
Vehicle: 1973 450sl
So I have been working on my 73' 450sl and today took it for a test drive, ran great and far better than expected for how long it had been sitting, the thing that concerns me is I put 8 us dollars of 87 (regular) gas in it, when I was told I should use premium ONLY because of ethanol in lower octane gas, Should I drain the tank or will I be ok if I put in octane boost and at least 20 bucks of premium (91)? Thank you anyone who can help me out and (hopefully) put my fears to rest? This car means a lot to me and I would be very sad to have broken it already :P
Brian McAfee-McCallum is offline
post #2 of 9 (permalink) Old 12-01-2014, 10:09 PM
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 51 Post(s)
I can't see that such a small amount of 87 would make any difference. Just fill it up with premium and enjoy your car
Cheers John.
wroding is offline
post #3 of 9 (permalink) Old 12-01-2014, 10:39 PM
TCC&D's Avatar
Date registered: Nov 2010
Vehicle: 2010 GL 350 BluTEC; 1967 250SE Sedan (Euro).
If it doesn't knock, you don't need premium. The octane is to prevent pre-combustion (knock).
TCC&D is offline
post #4 of 9 (permalink) Old 12-02-2014, 04:04 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
I ran my 108 for years on the cheap stuff without issue.
Grubeguy is offline
post #5 of 9 (permalink) Old 12-02-2014, 04:48 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 80 Post(s)
My 1972 280 SE 4.5 has been running on 87 octane with ethanol ever since that blend was introduced - no problems whatsoever.
ejboyd5 is offline
post #6 of 9 (permalink) Old 12-02-2014, 05:26 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1574 Post(s)
US Spec 450sl is very low compression, 8 or 8.8:1 I can't remember. It doesn't need premium. I only run regular in almost all of my Old MB cars. The manual states that you can run lower octane fuel but might need to retard the timing (if you hear knocks). The spec timing on a 1973 450sl (5 degrees atdc at 750rpm idle with vacuum, 5 btdc without vacuum) isn't going to create any knocks. Then pretty much all the failure modes result in retarded timing:
- mechanical advance doesn't work --> retarded timing.
- points wear out --> retarded timing
Ok... Here's one that results in some advance, but isn't a big deal:
- vacuum retard fails --> 10 degrees advance at idle (to 5 btdc).
Ethanol is a real bummer, but the only parts I think it would ruin on a 1973 450sl would be:
- rubber fuel hoses (which always need to be replaced with time anyway)
- uhmm ... I can't think of anything else that would be ruined by ethanol on these cars. I tore one down to the pistons in the last few months too.
Hopefully not a major mistake on my 450SL-imageuploadedbyautoguide1417526640.172008.jpg
Hopefully not a major mistake on my 450SL-imageuploadedbyautoguide1417526671.905663.jpg
Hopefully not a major mistake on my 450SL-imageuploadedbyautoguide1417526708.860732.jpg
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #7 of 9 (permalink) Old 12-02-2014, 06:33 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
zero issue there , if you really worry , you could add some octane booster , but you really dont need to , keep on driving .
agillot is offline
post #8 of 9 (permalink) Old 12-02-2014, 07:16 AM
Date registered: Oct 2014
Quoted: 12 Post(s)
Yeah, as others have mentioned regarding higher octane, it's only there to prevent pre-ignition... knocking. As far as the ethanol part of the equation, I know there are a lot of complaints about ethanol, but it shouldn't affect the engine any worse than it affects everyone else's engine. I'm not sure if it burns hotter than non-ethanol gas, but your valve guides, seats, pistons, etc shouldn't be any weaker than everyone driving. If anything, MB engines seem to be more tank-like!
janikphoto is offline
post #9 of 9 (permalink) Old 12-02-2014, 11:29 AM Thread Starter
Vehicle: 1973 450sl
Thank you for the replies everyone! All good to know, my step dad made it sound like the end of the world (Although he may have been messing with me as his weird way of saying good job getting it going)
wroding likes this.
