first start in over a year. what to do? - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 11-28-2014, 05:54 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 480 Post(s)
Time for some new calipers. water in the brake fluid causes rust internally. brake fluid should be be changed regularly.
rumb is offline
post #12 of 12 (permalink) Old 11-28-2014, 08:10 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1717 Post(s)
A year isn't that long. Heck, does the battery even need charging?
On the black 1972 250c I'm bringing back, someone had unbolted the rear driver caliper and tossed it over the axle. I drove it around the block that way. I still have a stuck caliper as I actually had to push it to get it to roll down a hill (to the side of the road) when it stalled as I embarked around the block. So I too will be redoing the brake.
All I did before I turned the key on my 250c that hadn't been started in a year was check the fluids and turn the key. I did find several very very messy problems due to rotten and eaten hoses (that the PO warned me about) including:
- rotted and missing fuel hoses
- rotted and eaten transmission lines
- an eaten oil pressure gauge line
From what I understand, the m130 (assuming that's what you have) is a pretty robust motor.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
