Electronic distributor for 1970, 280 SE 3.5 cb - Page 2 - Mercedes-Benz Forum
post #11 of 26 (permalink) Old 11-24-2014, 08:57 AM Thread Starter
Date registered: Nov 2014
Vehicle: 2 1970 - SE and SL cabriolets
Problem is that the car is not firing on all cylinders, is missing and sounds awful. The mechanic changed the spark plug cables , the distributor cap and head. Still no results and the problem is worse and I don't want to go back to this repair shop and there is no other reliable one who can care for classic Mercedes. Its a real pain. I thought that the classic center should be able to get things right even if I have to pay a high price. So that is the summary of things.
athadani is offline
post #12 of 26 (permalink) Old 11-24-2014, 09:07 AM
Date registered: May 2014
Vehicle: 1988 300e 75 300d 74 450sl
Quoted: 191 Post(s)
your original distributor is mechanical. points are a mechanical trigger for electric coil. electric would be a electrical pickup that does not move or wear.
yes electric is availlible call pertronics give them the numbers on the distributor and they can send you the correct setup. i have done this on one distributor of this type trigger points will not be changed only ignition points. it works great and have done dozens on the six cylinders
i have also seen the bushing worn and the shaft not spinning straight and cause misfire or rough running. bushing is not hard to change
athadani likes this.
rollin560 is offline
post #13 of 26 (permalink) Old 11-24-2014, 11:16 AM
Date registered: Feb 2009
Quoted: 12 Post(s)
still not convinced it is a matter of ignition ...
Could be also a matter of no petrol in some cilinders ....
paul-NL is offline
post #14 of 26 (permalink) Old 11-25-2014, 09:01 AM
Quoted: 191 Post(s)
is he trying to convince you or is he trying to fix car?
have you seen or drove car? there are many posibilitys of what it could be wrong its all a process of elimination. worn bushings in dist can cause all sorts of problems with points and can be cured by elecronic ignition
check the dwell on the points
while car is running unplug injectors one at a time that will tell you if they are working and how much that cylinder is contributing. it will also tell you what cylinders are misfireing. you can pull plug wires one at a time also but injector wire wont shock you
post #15 of 26 (permalink) Old 11-25-2014, 01:46 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 107 Post(s)
Yes yes, that too. BUT, there is no harm in a Pertronix setup - I would bet Paul's left arm that the conversion would only improve the way the car runs.
Grubeguy is offline
post #16 of 26 (permalink) Old 11-25-2014, 03:27 PM
Quoted: 12 Post(s)
He wrote : " The mechanic changed the spark plug cables , the distributor cap and head. Still no results and the problem is worse "
So the cause is imho obviously NOT the ignition ..... BUT the injection .....
Could be a faillure of the computer or the "trigger / contactpoints" for the D-Jetronic Injection in the bottom of the distributor ........
paul-NL is offline
post #17 of 26 (permalink) Old 11-25-2014, 05:06 PM
Quoted: 191 Post(s)
if the problem got worse than you are in the right area. im sure this wire harness is probably original. this system operates on resistance values and that can change with harness temp they also have a manifold press sensor that can be adjusted. my bet is on the distributor bushings if the shaft wobbles it will be inconsistant. check dwell at different rpms if its not the same there is a problem
i know i could fix it for you but it looks like you are not close to northern california
post #18 of 26 (permalink) Old 11-26-2014, 03:15 AM
Grubeguy's Avatar
Quoted: 107 Post(s)
The mechanic changed the cap and rotor but may have left the points and condenser. Ignition is not yet ruled out.
Athadani, the trigger points are in the front of the distributor and can be removed in less than two mins (seriously) with the use of a Phillips screw driver. Take the thing out and look for carbon, grime, crap, etc. Using acetone (nail polish remover), clean the contact points with a q-tip or used toothbrush. Do the same with the plug. Reinstall and plug the thing back in.
Honestly, I'm not thinking the problem is with the trigger points, but with the ignition points (and condenser). I replaced my Fiat's condenser with a new one, but the new one was bad too. Like my 108 previously, the Fiat ran like a bag of hammers until I installed the Pertronix. The difference was night and day.
Once you do this, I'd bet Paul's remaining arm the problem goes away.
HOWEVER, if the problem persists, I'd look to wiring or plugs/contacts. You can check this with a multimeter, and without shelling out tons of $$ at the classic center.
Tell me, did you buy the car with these issues? Have you owned the car for eons and the problem just started? Has there been a graceful degradation to the current crappily-running state?
These answers and more can aid in our pointing you toward further troubleshooting steps as required.
Grubeguy is offline
post #19 of 26 (permalink) Old 11-26-2014, 07:53 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
when you own a EARLY EFI car , you need to have a mechanic stethoscope so you can hear the injectors working , when you have a problem with trigger pointes [ common ] you loose 2 injectors per pointes set [ you have 4 ] . the common problem is oil leaking inside bottom of distributor , and the pointes get wet .so get a stethoscope and report your finding .1 and 5 4 and 8 2 and 7 3 and 6 injectors are together .
rollin560 likes this.
agillot is offline
post #20 of 26 (permalink) Old 11-26-2014, 01:00 PM
Quoted: 191 Post(s)
and the reason oil gets on them is that the bushings are worn and oil gets pushed up past them
unplug the injector and you can tell if it is working
with a screw driver tip on the injector and the handle at you ear you can hear the clicking but that only tells you that the solinoid is moving does not tell you how the injector is spraying
