My First Benz: W108 72 280SE - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 11-04-2014, 12:26 PM Thread Starter
Date registered: Nov 2014
Vehicle: 1972 280SE
Quoted: 5 Post(s)
Thanks guys. It does start very hard but in addition has a pretty bad misfire. I cleaned the points, cap, rotor and will say it needs a tune-up pretty bad. The parts list goes up but I know it'll pay off once I get her on the road
Here's my Todo list so far:
New tires (recommendations on white walls?)
engine oil, rear diff, brake fluid change (check pads and lines)
adjust valves, upper gaskets
fuel filter, rubber lines
convert to pertronix, coil, wires, plugs, cap, rotor
repair driver window regulator (might have to weld in new teeth)
heater control levers
If you're curious about whats in the corral. This might be interesting :P
01 Jetta Wagon VR6 5 speed
86 Toyota MR2 (2zz-ge swap)
57 Ford F100 (FI 302 + 4r70w trans)
57 Cardinal Deluxe Camper
The W108 will be replacing my MR2 as I've ran out of spot for cars.
bdub03 is offline
post #12 of 14 (permalink) Old 11-05-2014, 07:54 AM
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
I just bought a set of whitewalls for my car. 205/75/14 they are Hankook and readily available on line for about $60 each. I got them on recommendations from this site they seem to be very good value. Here is a picture on the car which looks similar to yours.
Cheers john.
ID:	1189850   Click image for larger version
wroding is offline
post #13 of 14 (permalink) Old 11-05-2014, 07:56 AM Thread Starter
Vehicle: 1972 280SE
Quoted: 5 Post(s)
John,
We're not to far from each other. Thanks for the recommendation and we should meet up once I get the Merc road happy.
bdub03 is offline
post #14 of 14 (permalink) Old 11-05-2014, 10:20 AM
wroding's Avatar
Quoted: 58 Post(s)
Originally Posted by bdub03 View Post
John,
I would really enjoy that
All the best john.
wroding is offline
