Mercedes W108 / W109 wheels 9J - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-01-2014, 01:18 PM Thread Starter
Tom_Lca's Avatar
Date registered: Jun 2013
Vehicle: W123 1985, W126 1987, W109 1968
Hi
Does wheels RIAL MESH 8J and 9J 16" ET11 will fit to Mercedes w108 or W109 ? 9J on rear will be OK ?
Thanks
Tom_Lca is offline
post #2 of 2 (permalink) Old 11-03-2014, 05:30 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1653 Post(s)
I never tried a w108/109 but someone came by with a fintail with stacked headlights (the predecessor that looks identical in the front to me), and he turned down the option to buy 7x16 et37 with 205/55/16 tires because they appeared as if the might rub on the outer edges. I pointed out that this circumstance would be unlikely to occur because it required the wheel front to be pointed out and the suspension on that side to be compressed. Normally the tire front would be pointed in when compressing the outside side when taking a turn. Regardless, he turned them down because 205/55/16 on et37 appeared to be too much tire. I think if you put the same on et11 it probably would not have even fit at all, especially in the rear, which certainly didn't have an extra inch on the outside (the difference between et37 and et11).
The red pig / sow car certainly has some big wheel on it though. They look like AMG Pentas but are actually the same wheels that MB put on the c111. I guess that red pig was a little modified though. C111 info: http://www.lotusespritturbo.com/Mercedes_C111.htm
Mercedes W108 / W109 wheels 9J-imageuploadedbyautoguide1415017670.965160.jpg
Mercedes W108 / W109 wheels 9J-imageuploadedbyautoguide1415017817.687910.jpg
My signature:
Click for list of my 33 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
