280ce weather stripping - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-22-2014, 05:28 AM Thread Starter
Date registered: Aug 2014
Vehicle: 1979 280ce
Has anyone had experience with replacing door glass weather stripping? I am specifically referring to the weather stripping that the door window glass front and rear seals against. It has the velour feltish finish on the interior is the car.
Any help would be appreciated.
dereykp is offline
post #2 of 3 (permalink) Old 10-22-2014, 05:03 PM
Rub1x's Avatar
Date registered: Jun 2005
Vehicle: 1973 W107 350SL, 1985 W123 280TE, 1983 W123 230E, 1996 W202 C280
Quoted: 9 Post(s)
Might need to know what model (chasis) this is as you have only mentioned its a 280ce, that could be 2-3 different cars. W114? W123? W124? Year will tell us at a bare minimum.
Auckland NewZealand.
Rub1x is offline
post #3 of 3 (permalink) Old 10-27-2014, 06:58 AM
Date registered: Oct 2014
Quoted: 12 Post(s)
I've found that it's similar on many older cars, often pressed in to a channel. You'll remove the window, then some gentle prying will do the trick. Check for YouTube DIY videos, as someone may have done a video on your car already!
janikphoto is offline
