75 450sl pertronix elec module - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-17-2014, 11:18 AM Thread Starter
Date registered: Oct 2014
Bought this electronic module (custom made, they said)from pertronix awhile back, but no one seems to know how to hook it up. had it running VERY poorly for a short while last spring...now no go. I am unclear where the red/black wires need to hook up (appears at the resister on drivers side firewall?)....alternately I'd like to go back to points (dealer says there is no condenser for this model needed, but unclear how to wire it), until someone can help me. My silver baby needs some body work, but was running fine till I mucked up the Haley circuit board, rendering it useless.
anyone have a schematic I can refer to---or similar experience? new here, so not sure how to access old threads pertaining to this question.
BB450sl is offline
post #2 of 5 (permalink) Old 10-17-2014, 11:44 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1573 Post(s)
107 forum has lots of help with pertronix on d-jet 107s.
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 5 (permalink) Old 10-17-2014, 07:13 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 34 Post(s)
First some basics. Which pertronix model did you buy? What coil are you using?
pertronix are pretty bullet proof and should only take an hour at most to install.
TZ_280SEL is offline
post #4 of 5 (permalink) Old 10-17-2014, 09:37 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
As mentioned above .
Share the installation you did ,most likely a error in connecting the red wire ,it connects to a12v supply wire directly not via the resistors which will cause a misfiring condition.
adler is offline
post #5 of 5 (permalink) Old 10-18-2014, 06:27 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Bypass the resistor entirely. The red wire hooks up to the voltage side of the coil (blue, or red, or some other color). The black wire hooks up to the other side of the coil, which will have a brown or black wire. It may even have a + and - stamped on it (red to +, black to -). Did you buy the pertronix coil too? If not, I'd recommend getting it. It'll make a difference.
Grubeguy is offline
