220d oil filter change ? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-16-2014, 07:18 AM Thread Starter
Date registered: Oct 2014
I have a 1970 220d . I bought a oil filter kit. It came with 3 washers. 2 small ones and a large copper crush washer that I have no idea were it goes. The small one goes on the oil pan drain plug, the other small one goes on the bottom of the bolt of the oil filter housing but we're does this large one go?
Dragunov is offline
post #2 of 6 (permalink) Old 10-16-2014, 08:56 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
there are 2 possibilty for drain plug , a small one or a large one , also the drain plug at oil cooler [ dont mess with this ] , also early diesels had a drain plug on the oil filter canister . a warning , when you put the canister back in , make sure that the o ring , lip , is properly engaged in housing , or you will crunch the canister .use your hand to feel .
agillot is offline
post #3 of 6 (permalink) Old 10-16-2014, 10:18 AM Thread Starter
Ok got it thank you. The oil drain plug on the cooler why should I not drain it?
Dragunov is offline
post #4 of 6 (permalink) Old 10-16-2014, 11:40 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
there is a chance of stripping the treads , not enough oil in there to worry about .use 15/ 40 shell rotella T [ wall mart ]
agillot is offline
post #5 of 6 (permalink) Old 10-16-2014, 01:37 PM Thread Starter
Ok but when I did my last oil change instantly turn black as soon as I turn the car on I figured because it mixed with the oil that was in the cooler is this normal
Dragunov is offline
post #6 of 6 (permalink) Old 11-26-2014, 04:51 PM
Date registered: Jun 2011
Vehicle: C230 Sport, 1971 220D
Quoted: 5 Post(s)
Dragunov,
Mine was changed twice directly before I picked it up. It was still black as coal.
I had the synthetic removed and regular diesel oil put in. The mechanic that worked on the car for most of its' life said no synthetic.
Tim
biggreen1 is offline
