Voltage drops on acceleration - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-14-2014, 11:00 AM Thread Starter
Date registered: Dec 2012
I am troubleshooting charging in my 77 280SE. What confuses me is that when there is acceleration the voltage output drops?
Anyone know what might cause this, to go from 12.8 to 11.7 when accelerating?
Thanks!
Dayminder is offline
post #2 of 8 (permalink) Old 10-14-2014, 01:46 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Bad regulator, eh?
flyboyike is offline
post #3 of 8 (permalink) Old 10-14-2014, 03:36 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
Does it also change with the addition of load to the system (turn on high beams and blinker). If yes, I would lean toward regulator.
Does this year have the regulator integrated with the brushes in the alternator? Worn brushes could "float" with the increased rpm of the alternator causing the drop in voltage.
TZ_280SEL is offline
post #4 of 8 (permalink) Old 10-14-2014, 05:58 PM Thread Starter
Originally Posted by flyboyike View Post
Bad regulator, eh?
Where is the regulator? Thanks for the reply.
post #5 of 8 (permalink) Old 10-14-2014, 06:40 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
I believe the regulator is build into the alternator. So you must replace the alternator. Smarter minds will chime in wilh a more definite answer.
Baybear
Baybear is offline
post #6 of 8 (permalink) Old 10-15-2014, 08:43 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
loose belt ???? .the regulator is at rear of alternator , 2 screws , easy to replace on car .
agillot is offline
post #7 of 8 (permalink) Old 10-17-2014, 07:12 AM
flyboyike's Avatar
Quoted: 69 Post(s)
This is the regulator, it's on the back of the alternator.
Your Parts Search Returned 5 Part(s)
Alternators are reasonable, too, plus they come with the regulator included.
Your Parts Search Returned 2 Part(s)
post #8 of 8 (permalink) Old 10-17-2014, 09:14 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
if the brushes on alternator are worn and not making contact , the alternator light will not come on when turning ignition on .
agillot is offline
