Changing to power steering w111 sedan - Fintail - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-11-2014, 03:13 AM Thread Starter
Date registered: Aug 2011
Vehicle: w111, 220 SE, automatic, 1964
I’m pretty new to the forum and MB Fintails. In my search for a decent Fintail I’ve realized that the standard steering is pretty heavy. I know that power steering was available as an optional extra - at least for the latest models/years. However, how “simple” is it to change from standard steering to a power steering unit? Is the unit available as an aftermarket part? Can I use i.e. power steering from a w108 – or other models? Or do I simply need to search for a used unit from a w111?
Thanks in advance for any input and advices
Einar2 is offline
post #2 of 5 (permalink) Old 10-11-2014, 08:04 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
it s not simple , i think you also have to replace the steering column [ different length ] .
agillot is offline
post #3 of 5 (permalink) Old 10-17-2014, 04:10 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Seen someone add on a electric power steering unit on a standard steering keeping all original items.
adler is offline
post #4 of 5 (permalink) Old 10-17-2014, 10:08 AM
suktinis's Avatar
Date registered: May 2009
Vehicle: Ferguson TED-20 1956, Mercedes-Benz 220 S 1963, Valmet 502 1973, Mercedes-Benz S 500c 1996
Quoted: 5 Post(s)
Hej Einar!
I checked in the EPC, and the support, pump and steering box seems to have the same partnumber on an W108 (at least with the six cylinder engines)
Agillot was correct, there is a different steering column shaft for the servo cars as well.
I would assume that this is a project which includes a fair amount of work, but still quite possible.
I dont know where in norway you are, but check out this link
Flera olika Mercedes skrotas | Älvsborg
You might get lucky!
Just be sure that all the seals etc are in perfect order before you install it into the car!
suktinis is offline
post #5 of 5 (permalink) Old 10-18-2014, 08:17 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 102 Post(s)
I don't have power steering and don't find the steering to be heavy at all. What size tires are you using?
Scoot is offline
