250SE tachometer - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-07-2014, 06:25 PM Thread Starter
Date registered: Mar 2007
Vehicle: 190sl 220se coupe 250se cabrio
250SE tachometer
I am putting my 250SE cabrio back together and find that there is no tachometer cable and no place for the tachometer cable to connect to the engine. There is a bolt on the block where I would expect the connector to be. The tach that came with the car has a female connector for the cable.
I read on the Pagoda site that one difference between the SE and SL engines is that the SE does not have a tach but obviously that can't be correct. Does the SE have an electronic tach or am I missing something? Some parts books show the tach but no cable.
MBdrvr347 is offline
post #2 of 3 (permalink) Old 10-08-2014, 09:35 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1488 Post(s)
Assuming you have an M129 engine, the tach drive is located just below and forward of the #1 spark plug. It should look like the one in this pic
Zeitgeist is offline
post #3 of 3 (permalink) Old 10-08-2014, 05:49 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the SE car has NO tach .you could swap the gear and top cover from one engine to the other [ easy ], the picture show nicely .
agillot is offline
