No Dash Lights 1975 mercedes 450 SEL - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-06-2014, 03:37 PM Thread Starter
Date registered: Sep 2014
Vehicle: 1975 Mercedes 450 SEL
Quoted: 14 Post(s)
Any Clue what may cause this ? NO DASH LIGHTS
Whats been done so far . I Bought the car like this .
(1) turned Dash Light dimmer switch back and forth
(2) Checked for Fuse under hood > all ok Dash lights same as Parking and they work
All Gauges are working in Instrument Cluster
Any Search for Cause Tip's Appreciated . By the way ? whats in their in the Cluster ? I hope not a printed circuit yuk .
With totally nothing working ( Lights ) I am thinking a Fuse / disconnected wire / a Bad switch .
I Kind of doubt all the bulbs are just burned out but is possible ?
Just thought I would ask before I dived in
Regards to the forum
aluminum is offline
post #2 of 5 (permalink) Old 10-06-2014, 04:27 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
No circuit board, just a resistor in the dimmer knob. New ones go for around $90, used $30 or so. Will require the cluster to come out.
Your Parts Search Returned 1 Part(s)
You're welcome. Again.
flyboyike is offline
post #3 of 5 (permalink) Old 10-06-2014, 05:02 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the dimmer switch goes bad , you can bypass it with a wire at the 2 pin , so the light will be on .
agillot is offline
post #4 of 5 (permalink) Old 10-06-2014, 06:10 PM Thread Starter
Quoted: 14 Post(s)
thanks the 2 Pin ?
Thanks Much :
Question
just guessing but by bypassing the 2 Pin I expect your talking at the Resistor behind the Instrument cluster correct ?
or is it ( this number 2 pin somewhere else perhaps ? )
I did this same thing on my 928 Porsche dimmer switch and got full power at the Cluster lights ( still very dim however ) and went for LED Bulbs
aluminum is offline
post #5 of 5 (permalink) Old 10-12-2014, 08:59 PM Thread Starter
Quoted: 14 Post(s)
resistor picknpull
Thanks I picked one up at Picknpull for free with a window regulator ( $20 ) from a 79 year model . was going to just run it full power but what the heck I changed the part .
I bit tricky working on the cluster but not so bad
thanks for the help
aluminum is offline
