Time-late question about Pertronix - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-01-2014, 06:43 PM Thread Starter
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
I've since sold the car I installed a pertronix in, but a question has come up that now has me curious.
When I put the thing in, I never changed the spark plug gap. I'm now told that the proper gap, regardless of the car a pertronix goes on, is .030 (or is it .30).
Can someone verify this?
Grubeguy is offline
post #2 of 6 (permalink) Old 10-02-2014, 07:20 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
According to the Pertronix manual:
What should I gap the spark plugs to?
The Ignitor has no set specification in which the spark plugs should be gaped at. Every engine responds differently to spark plug setting. In most cases increasing the factory recommended gap by .005 improves the engine performance.
TZ_280SEL is offline
post #3 of 6 (permalink) Old 10-02-2014, 07:44 AM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
I believe you may be referring to the air gap between the module and magnetic sleeve within the distributor. On some models it is adjustable and others it is not.
Will
Baybear is offline
post #4 of 6 (permalink) Old 10-02-2014, 09:34 AM Thread Starter
Grubeguy's Avatar
Quoted: 99 Post(s)
No no, I'm specifically referring to spark plug gap. I'm being told .030 is the acceptable gap for all plugs with a pertronix, but I can't verify it. TZ_280SEL's reply rings a bell too. I'll give that a shot
Grubeguy is offline
post #5 of 6 (permalink) Old 10-02-2014, 10:42 AM
Quoted: 37 Post(s)
Looking at the Pertronix website under "troubleshooting tips" verifies
TZ_280SEL's post.
Will
Baybear is offline
post #6 of 6 (permalink) Old 10-02-2014, 11:30 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
The Pertronix ignitor is basically a electronic switch which does not modify the output voltage , their coil does give the high voltage option.Spark plug gap of .80mm is correct.
adler is offline
