Starting a 1985 300 D after it has sat 3 years - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-20-2014, 04:05 PM Thread Starter
Date registered: Sep 2014
Question Starting a 1985 300 D after it has sat 3 years
Hello,
I have a 1985 300 D that has sat 3 years without being started.
I attempted to start it after fully charging the battery and just heard the click of the starter solenoid. I know that the Battery is sound and is holding a full charge, and I believe the starter is good., but I think things may have gotten a bit "stuck" and there is too much of a load to turn that mighty 5 cylinder diesel . Is there a good way I can manually turn this over ? If so which way(as you face it) does the engine turn.
This would be fairly straight forward for me if this were a gas engine, but I am not that well versed with diesel, any suggestions would be appreciaterd
Thank you,
Paul
Paul0110 is offline
post #2 of 5 (permalink) Old 09-20-2014, 06:13 PM
Date registered: Jul 2008
Quoted: 340 Post(s)
Try turning the engine over by hand, 22mm wrench on the power steering belt usually works. If you attempted to charge the battery that has sat in that car for 3 years, chances are that it has a dead cell....go buy a brand new battery...
cooljjay is offline
post #3 of 5 (permalink) Old 09-21-2014, 08:35 AM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
Corrosion on the battery terminals? You might not see it on the outside, could be worth a look. Do try a jump start - your current battery could be weak.
Having said all that do you know that it was running for sure when it got parked 3 years ago?
Frank Flynn
'73 220D
'88 300SEL
'91 300TE
frankflynn is offline
post #4 of 5 (permalink) Old 09-21-2014, 01:36 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Proceed to the W123 forum, they're almost all dieselheads there.
flyboyike is offline
post #5 of 5 (permalink) Old 09-23-2014, 05:53 AM
Date registered: Oct 2013
Vehicle: 1982 240D, 1984 Euro 300TD
Quoted: 36 Post(s)
I've had new batteries turn to junk after sitting for only 1 - 2 years. You charge & charge & charge them and they still won't handle the starting load. Do your dash warning lights blink out when you try the starter? If the cable connections are OK, just save time & aggravation and get a new battery. Or, if you're reluctant to invest in a new battery yet, at least try it with one out of a currently running vehicle.
Happy Motoring, Mark
cooljjay likes this.
Mark DiSilvestro is offline
