D JET ECU WANTED BOSCH 0 280 002 014 - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 09-20-2014, 10:39 AM Thread Starter
Date registered: Sep 2014
Vehicle: 1975 Mercedes 450 SEL
Quoted: 14 Post(s)
Hello Found that my ECU Unit is burned up inside and not sending signals to the Fuel injectors to give gas . Anyone have a good working used one ?
BOSCH 0 280 002 014 is the number on it
1975 Mercedes 450 SEL ( a 4 door sedan ) Understand a 107 may also work on this 116 type also a BOSCH 0 280 002 014 ( that may be a Mercedes SL )
I will call Bosch on Monday and check to see what I can learn of the Interchange if any 1 888 715 3616 Perhaps I will get lucky and get some help with this. I Know I can buy a Re manufactured one but they are Expensive and a working used one is fine with me .
This ECU is located in the Passenger side foot well in the kick Panel on the right . Just Pops out after removing panel cover ( 1 screw to remove panel cover ) Pry on Bottom edge of ECU Gently and it will pop out . Is about 13 inches long and 7 Inches wide " Approximately "
see photos Thanks see Photos of Unit D JET ECU WANTED BOSCH 0 280 002 014-dsc07913-001.jpg
aluminum is offline
post #2 of 10 (permalink) Old 09-20-2014, 04:58 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1805 Post(s)
Have you been able to confirm it's the ECU and not the wiring harness?
I already sold the ECU from my 1972 450sl, but I'm in the process if making a 1973 450sl run. The car should probably be parted out, and I will eventually have one for sale most likely. But... I bet you can pick one up on ebay. These don't fail too often, but it's good to have a spare on hand anyway. D-jet owners are smart to have spares of everything really.
I do have a wiring harness ready to go if you have any fear that could be your problem.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 10 (permalink) Old 09-20-2014, 07:30 PM Thread Starter
Quoted: 14 Post(s)
Hello Thanks for reply
Yes ? did you see the photos ? burnt up ECU here is another Photo
Car I am working with is a 1975 Mercedes 450 SEL 4 door sedan . do you have a wiring harness for that or for a SL Model ?
The Wiring looks good so far but have not done a complete inspection as of
yet . The ECU I can buy New for only $195 with warranty . from ProgRama
Link : http://www.programainc.com/categorie...egory=602&cl=1
they are to much at ebay , from a salvage yard I expect I can find one for $50 to $80 however I am in a rural area and would have to travel to get it.
ID:	1131801   Click image for larger version
ID:	1131809   Click image for larger version
aluminum is offline
post #4 of 10 (permalink) Old 09-21-2014, 04:11 AM
Fonzi's Avatar
I don't know how similar the layout is in a w116. In a 107, the harness comes through the firewall near the right valve cover. I'm trying to think if all the components it hits, like the MPS on the driver fender. Otherwise, I think all the components are on the engine and should be in the same place.
My signature:
Fonzi is offline
post #5 of 10 (permalink) Old 09-22-2014, 10:00 PM
cushjbc's Avatar
Date registered: Dec 2010
Vehicle: 1973 450 SL
Quoted: 207 Post(s)
Aluminum,
My parts spread sheet says I have a 0 280 002 014 pulled from 1975 450 SEL (116 033 12 030272). PM me if you still need one. I'm interested in your old one so I can build another breakout box by harvesting the card edge connector. I also have numerous 107 and 116 engine harnesses because of this project:
http://www.benzworld.org/forums/r-c1...e-harness.html
I'm rebuilding a 107 harness right now.
Brad Cushman
73 450 SL
cushjbc is offline
post #6 of 10 (permalink) Old 09-22-2014, 10:11 PM
cushjbc's Avatar
Quoted: 207 Post(s)
I found some pictures of it.
Name:	1975 450SL  (4).jpg
ID:	1134498   Click image for larger version
Name:	1975 450SL  (5).jpg
aluminum likes this.
Brad Cushman
73 450 SL
cushjbc is offline
post #7 of 10 (permalink) Old 09-23-2014, 08:51 AM Thread Starter
Quoted: 14 Post(s)
RE ECU sent PM
Originally Posted by cushjbc View Post
Aluminum,
Thanks sent you a PM I am interested in the ECU and condition of it
aluminum is offline
post #8 of 10 (permalink) Old 09-23-2014, 09:03 AM Thread Starter
Quoted: 14 Post(s)
Great looks good .
Looks just like mine except for the smaller Number code's on the Tag .
Main number is exact match 0 280 002 014 and from the Exact year model car 1975 Mercedes 450 SEL you mention .
Photo of my Tag here
aluminum is offline
post #9 of 10 (permalink) Old 09-25-2014, 03:11 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
try BRINSON CO 1 800 535 8788 .on the east coast .a lot of reman stuff for older cars . looking at the picture of circuit board , i wonder if there is a short somewhere . you could solder a wire across the burned spot , and you may get lucky .
agillot is offline
post #10 of 10 (permalink) Old 09-28-2014, 09:56 PM Thread Starter
Quoted: 14 Post(s)
Thanks to forum members I found a ECU from this page and It's in the mail should be here in a day or 2 .
I could have got a New Re Man unit for $200 but decided to go with a original used unit said to be working perfect . The car is now running ok Even tho the ECU is Bad and has Issues . I am lucky about this because make it easy to know the upcoming Unit is working well .
Thanks Everyone for the effort
here is the link :
for the RE Man Unit for $199 ProgRama Many other venders sell their units for over $500 so this is the place to get them
Link :
Professionally remanufactured parts with extended warranty
aluminum is offline
