Car shuts off when car gets to operating tempature - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-01-2014, 08:45 AM Thread Starter
Date registered: Sep 2014
anyone have any ideas. I have a 76 300d 115. the car runs fine until about 15 min, than the car shuts off. the car cranks fine it will start for a second and shuts off. after letting cool down its starts up fine and drives perfect. I have changed fuel filters and I notice that the clear filter is full of fuel when problem is occurring, I did take the fuel filter cap of other filter and noticed that the fuel was only half way up the canister,also the prime button seems to stick in place I have to manually lift button up.
Burksbenz is offline
post #2 of 4 (permalink) Old 09-01-2014, 03:15 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
from what you describe [ pump handle stick at bottom ] the screen at gas tank is plugged ] on a 76 it is at bottom of tank , easy to get too .get a new one , and swap quickly , [ need a o ring ] , no need to drain tank . if you want to use old one , then drain tank , clean old one and put back in .
agillot is offline
post #3 of 4 (permalink) Old 09-01-2014, 07:36 PM
Date registered: Jul 2008
Quoted: 320 Post(s)
Once these cars are started, nothing will stop them from running, unless the fuel supply is cut, breather covered or a vacuum is applied to the shut off....try to remove the brown line going to the injection pump and see if the issue is still there..
Be your own person...
Drink the Kool-Aid....
cooljjay is offline
post #4 of 4 (permalink) Old 09-04-2014, 02:13 PM
tewfiks's Avatar
Vehicle: Many MBZ, Couple of 911s, couple of pick ups
Quoted: 44 Post(s)
sounds like something my 123 wagon was doing. Turned out to be the vacuum lines needed replacing.
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
11 E350 4matic Wagon
tewfiks is offline
