1967 Mecedes Sedan - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 08-08-2014, 08:50 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Looks like a 250S (carbs) Was it a running and driving car when parked? if so should not take too much to get it going again so you can evaluate before starting work. good thing is there were a lot of these 108 chassis cars made through '73 so should be no problem finding bits that might have been misplaced. There are always a few in the Pick n Pulls around here. Again not a high dollar car so you have to deciede where you want to go with it.
Allenhomere02 likes this.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #12 of 13 (permalink) Old 08-08-2014, 08:56 AM Thread Starter
Date registered: Aug 2014
Vehicle: 1967 Mercedes Sedan
I believe it was running, when my dad had brought it home
Allenhomere02 is offline
post #13 of 13 (permalink) Old 08-11-2014, 07:00 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 458 Post(s)
Your car as is, may only be worth $500-$1000. A good paint job may cost many thousands of $.
Do you plan on doing as much work as you can yourself? Does this car have large sentimental value?
a new set of door seals is @$900, front seat covers $600. rebuilding carbs $6-800
If you do restore completely you could have a very nice car.
If the car means a lot to you and you have at least $6-8K to spend then do it.
The red paint on the engine is strange. It does look pretty solid as far as pictures so far.
rumb is offline
