1973 280SE 4.5 (W108) - Fuel Pump replacement - help me install it correctly please - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 07-28-2014, 07:26 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
this cis pump will work fine , keep it .
agillot is offline
post #12 of 14 (permalink) Old 07-28-2014, 07:51 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1680 Post(s)
1973 280SE 4.5 (W108) - Fuel Pump replacement - help me install it correctly ...
No worries of fuel leaks and fire under his hood? Would you be able to sleep at night if something bad happened to the car or a person?
Here's what I was reading:
http://www.benzworld.org/forums/r-c1...ml#post9480225
Sent from AutoGuide.com App
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #13 of 14 (permalink) Old 07-29-2014, 08:09 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
last post on that , but this cis pump is been used on older non cis cars now .either you gave the wrong year to the restoration center [ 1983 / 1973 ] or they feel comfortable in using this pump .[ i am ] .so give them a call to double check . i would make sure you are using good [ high pressure ] fuel hoses on this .
agillot is offline
post #14 of 14 (permalink) Old 07-29-2014, 09:20 AM
Fonzi's Avatar
And it sounds like if you were to put in a 71 psi (or lower) pressure relief with fees back to the tank or pump inlet, you'd be OK. I will agree that if that's as complex as the mod needs to be, there's a lot of fuss about these d-jet pumps. I am sure there are plenty of d-jet cars with CIS pumps, hopefully with fuel pressure regulators doing their jobs.
So where do you get a relief valve to install on the pump outlet?
Edit:
Oh. Does the CIS pump have a check valve like the d-jet pumps do? I know CIS systems use an accumulator needed for hot starts. I would hate to exacerbate the hot start (vapor lock) issue that d-jets already have by using a pump with no check valve.
My signature:
Fonzi is offline
