W109 300 SEL Heater Lever Replacement - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-20-2014, 08:52 PM Thread Starter
Premium Member
Date registered: Dec 2013
Vehicle: 1973 280SE W108, 1971 300 SEL 3.5
Premium Member
Sunday's all day project: installing new heater levers to replace all four of the existing broken ones. I followed this great article http://w108.org/articles/heaterlever1.pdf and used all factory parts from MB Classic. While not for the faint of heart, the work was manageable and I only encountered a few hiccups along the way. The biggest issue was replacing the seals on the heater valves, one of which was leaking. The article mentions marking the valves to make sure they're installed in the same position before removal. Sadly, they didn't mention that the valve stem position is the crucial item, not the retaining ring. Took about a half hour to figure out the correct position during refitting. However, the levers all work great now and everything is functioning as it should. I left the aftermarket radio out in preparation for the original Becker to be reinstalled. MB sure knows how to make things complex!
Name:	300 SEL Dash Apart 2.jpg
ID:	1044457   Click image for larger version
Name:	300 SEL Heater Lever Assembly Start.jpg
ID:	1044465   Click image for larger version
Name:	300 SEL Heater Lever Disassembled Top.jpg
ID:	1044473   Click image for larger version
Name:	300 SEL Heater Lever Assembly Top.jpg
ID:	1044481   Click image for larger version
Name:	300 SEL Heater Lever Done.jpg
Name:	300 SEL Heater Lever Assembly Bottom.jpg
ID:	1044529   Click image for larger version
Name:	300 SEL Dash Apart.jpg
daveburcher is offline
post #2 of 7 (permalink) Old 07-21-2014, 02:49 AM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 82 300D,90 350SDL,90 300SEL,98 S420,97 SL500,94 S420 former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 709 Post(s)
Nice job!
It's been some years since I've done a set of heater levers and valves, but I do recall that it wasn't a pleasant job. What's nice is when you're finished and how nicely they work compared to the way they had been previously....
Dan
LWB250 is online now
post #3 of 7 (permalink) Old 07-22-2014, 09:38 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
Well done. That is a big project.
rumb is offline
post #4 of 7 (permalink) Old 07-22-2014, 09:56 AM Thread Starter
Premium Member
Premium Member
Thanks for the encouragement! It is definitely a satisfying conclusion to have the levers and all associated items working.
post #5 of 7 (permalink) Old 07-23-2014, 06:16 AM
67300se5spd's Avatar
Date registered: Dec 2006
Vehicle: 2004 E320
Quoted: 10 Post(s)
I'm about to initiate having that done...I emphasize, 'having it done' because I just don't have the touch to get it done on my own....So my independent will tackle it. Your link will be on his screen . Thanks for sharing your journey...
67300se5spd is offline
post #6 of 7 (permalink) Old 07-23-2014, 09:56 AM Thread Starter
Premium Member
Premium Member
Good luck with the replacement. That link and article were invaluable to do the work. I ordered all of the parts mentioned using their newer numbers. I should have also ordered clips for the cable ends. I don't know if the part numbers didn't cross over correctly or if they simply weren't mentioned in the article. Who do you use as your mechanic in NYC?
post #7 of 7 (permalink) Old 07-23-2014, 11:13 AM
Vehicle: 2004 E320
Quoted: 10 Post(s)
Nobody in NYC.... I have a guy up in Massachusettes that handles my work.
If you know the part #'s for the clip ends mentioned, please pm me....
