1967 250sl fan shroud ? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-09-2014, 10:03 PM Thread Starter
tdoriot's Avatar
Date registered: Jul 2011
Vehicle: 1993 600SL, 1973 450 SL,1982 380SL,1998 SLK 230, 1968 Firebird, 2001 Dodge Ram 4x4,2005 Ford Escape
Quoted: 414 Post(s)
Post 1967 250sl fan shroud ?
Hey guys, I have a buddy that has a 67 250sl that gets close to hot in hot weather at slow speeds. I looked at it today and it has no fan shroud. I assume these had one. Anyone have one or at very minimum a picture of one? Alternate plan b is adding a electric fan on the front of the radiator. Since the problem only occurs at the extremes I assume abshroudwould solve the issue. Thanks in advance !
tdoriot is offline
post #2 of 5 (permalink) Old 07-10-2014, 02:57 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
dirty radiator ?? weak visco fan clutch , defective tstat , use a 75 deg num 116 200 00 15 behr .so , replace the tstat first , and dont go over 50/50 mix antifreeze .MB has the best one .
agillot is offline
post #3 of 5 (permalink) Old 07-11-2014, 02:09 PM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
As agilot said. An easy and cheap way to clean a radiator is with muriatic acid. I pour it straight into the radiator, let it sit for half an hour and then rince well with the garden hose in reverse flow. I then repeat the procedure. Then I neutralize with baking soda. Google the procedure, it's quite well explained on the net.
Next thing is to check if the visco fan clutch works properly. when hot, at idle, try to stop the fan with a rolled newspaper. If it stops the clutch needs to be replaced.
Next is to replace the 6 or 8 blade propeller by a plastic 9 blades one. They are cheap on the net. Finally, if it still overheats, try to find a fan shroud that fits. The 230s didn't have one, the 280s had one, I don't know about the 250. If so it was specific to the 250 as the radiator dimensions of the 250 is different from both the 230 and the 280. If you can't find an original one, try many until you find one that fits satisfactorily.
Finally, but only in last resort, go with a pusher electric fan in the front. GO with a SPAL one. Google it, apparently they are the only one that really do the job as advertised. On a250 SL you can go with a 16' one, but it's tricky. You may end up with some clearance issues and the hood may not stand open properly anymore. If the car has AC there is not enough room for a fan in the front.
Don't replace the mechanical fan by an electric one. It will be worse.
Don't ask me how I know all this.
Good luck!
GGR is offline
post #4 of 5 (permalink) Old 07-15-2014, 10:49 PM Thread Starter
tdoriot's Avatar
Quoted: 414 Post(s)
Post
Great info. Thanks for the reply. I'll relay those tweaks to my buddy. If anybody has a shroud for a 250 or 280 shroud let me know
tdoriot is offline
post #5 of 5 (permalink) Old 07-18-2014, 04:50 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
Fan shrouds appeared on late 230s, so a 250 should definitely have one. I would try SL-Tech (gernold@sltechw113.com) for a used one. They are a pain to install especially if the car has AC.
Good luck,
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
