Points change question - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 07-06-2014, 09:08 PM Thread Starter
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
Hi All
I just bought a set of new points for my straight 6. 280se
Can anyone give me some tips on turning the engine over to get the high lob in the right position in the distributor. i am having difficulty with access. I can't seem to get a wrench or socket on the fly wheel to manually crank the motor. What size and type of wrench should i use?
Thanks.
John.
wroding is offline
post #2 of 21 (permalink) Old 07-07-2014, 12:24 AM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
The engine will turn much easier with the sparking plugs removed, and one can even turn the engine round by applying pressure to the serpentine belt and using the fan blade ( with on non visco fan)
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #3 of 21 (permalink) Old 07-07-2014, 07:36 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Thanks Malcolm
I think the heat here is getting to me. I should have thought of that
Much appreciated.
Cheers John.
wroding is offline
post #4 of 21 (permalink) Old 07-07-2014, 07:39 AM
JN74SL's Avatar
Date registered: Apr 2013
Vehicle: Monika '74 450SL and her lil sis BrownHilda '79 280SL
Quoted: 215 Post(s)
I just bump the starter until it lines up. I have a remote starter switch that makes the job real easy
Current:
Reggie 2010 Range Rover Sport Supercharged
Monika '74 450 SL
BrownHilda '79 280 SL ex-Zender
Scarlett 2014 Jeep Cherokee 4wd
FoxyCleopatra '99 Chevy Suburban
Krystal 2004 Volvo S60
Gone:
Rudolf ‘86 300SDL
Bruno '81 300SD
Fritzi '84 BMW
'06 Volvo S60 AWD turbo
'97 Jeep GC
'96 Volvo 960
'96 Impala SS
'92 Subaru Legacy wagon
'74 Jeep CJ5
'71 Buick GS conv
'67 GTO conv
'63 Corvair conv
'57 Nomad
JN74SL is offline
post #5 of 21 (permalink) Old 07-07-2014, 08:28 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
bump the starter a few time , also if you are almost there rotate the rotor clockwise to align . invest in a meter made for cars , it will have a dwell reading so you can use that to set point gap [ cheap ] ebay .if you see something there , send me the item number so i can see if it is ok .
aluminum likes this.
agillot is offline
post #6 of 21 (permalink) Old 07-14-2014, 05:04 PM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 194 Post(s)
points are easier to adjust dwell. with engine cranking and dwell meter hooked up adjust. this is as close to running adjustment as posible is way more accurate than point gap. if you really want to set point gap get close with stater then losen distributor and move it to highest opening on points. then put back close to where it was the adjust timing with light and your done. useing dwell method you wont need a timing light anymore after first setting dont move the distributor and as points wear adjust dwell back to same as you set and timing will go back to the same as you set it
current stable
2010 glk350-86 300e-88 300e white-88 300e blue-66 220seb-74 230-89 560sec white-91 560sec taupe?-92 300te-83 380se parts car- 2012 chevy cruze eco wifes commutor 40plus mpg on regular. 1970 gmc 2500- 2002 gmc 2500hd duramax/allison-50s something willeys pickup- 74 scout-88 jetta karat-74 harley fxe-92 harley flhtcu ultra classic-95 harley road king-96 harley fatboy-98 special construction harley powered.- 2011 klx250 and to many off road vehicles and coming soon 69 280sl
1mbzdoc is offline
post #7 of 21 (permalink) Old 07-18-2014, 05:10 PM
Date registered: Oct 2013
Vehicle: 1982 240D, 1984 Euro 300TD
Quoted: 36 Post(s)
Don't forget a tiny bit of distributor grease at the place where the points ride on the distributor-cam. Don't want those new points wearing down prematurely.
Happy Motoring, Mark
Mark DiSilvestro is offline
post #8 of 21 (permalink) Old 07-19-2014, 01:59 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
I had Upgraded the 280s ignition with a Pertronix ignitor,still perfectly operational Fifteen years on.
adler is offline
post #9 of 21 (permalink) Old 07-19-2014, 03:24 AM
Quoted: 36 Post(s)
Only issue with an aftermarket ignition conversion is the ready availibility of parts if one of the electronic bits should fail suddenly.
Point problems can often be resolved (at least enough to get you home)
by cleaning or adjustment. Otherwise, it's a simple matter to carry a spare set in the car.
post #10 of 21 (permalink) Old 07-19-2014, 03:21 PM
Quoted: 59 Post(s)
My thoughts too initially but the Pertronix units have worked troublefree year after year in Six of my cars.
The instant starts smooth idling and maintainace free running add up.
adler is offline
