changing out flex hoses - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-01-2014, 12:35 PM Thread Starter
Date registered: Jun 2010
Hi All,
I just did a brake job on my '72 280SEL 4.5. Everything went fine, the brakes work great. But I was unable to replace the existing front flex hoses because I couldn't loosen the fittings! I tried all the obvious solutions, such as using penetrant, and then applying heat, etc. Even a sharp strike or two with a copper mallet, but no luck. (I haven't tried freezing and then heating.) Does anyone have some tips for loosening those fittings?
Thanks very much,
Neil
nsgarch is offline
post #2 of 3 (permalink) Old 07-02-2014, 06:12 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 88 Post(s)
Cut the hose, put a socket on the remaining end of the flexible line, firmly clamp the hard line and remove the female fitting. Heat can be a great assistance if the fittings are really stuck.
ejboyd5 is online now
post #3 of 3 (permalink) Old 07-02-2014, 09:58 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
sometime a sharp wise grip on the 11mm part will do the trick .
agillot is offline
