Impact Pin Nightmare 220D - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-30-2014, 05:59 PM Thread Starter
Cheetahpop's Avatar
Date registered: Mar 2013
Vehicle: 1971 220D
So I need a new head gasket (oil in the coolant, coolant in the oil and both going through the combustion chambers). I've got it all apart except for the "rail tensioner", which is held by an impact pin down between the water pump and the shaft pulley. It's threaded for an M8 bolt, and I was using a bolt to pull it out when the head of the pin sheared away from the shaft. So I try drilling it out. I got partway through, enough to loosen the leading edge of the tensioner, and then went awry. Now what? A hacksaw blade down beside the tensioner? Can I get at it better through the oil pan?
Cheetahpop is offline
post #2 of 9 (permalink) Old 07-01-2014, 07:10 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
head gaskets dont fail , the head does crack inside prechambers hole .
agillot is offline
post #3 of 9 (permalink) Old 07-01-2014, 07:37 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
How is that relevant to his current problem? To the OP, you got a photo of your situation?
flyboyike is offline
post #4 of 9 (permalink) Old 07-01-2014, 09:16 AM Thread Starter
Cheetahpop's Avatar
Vehicle: 1971 220D
Hear are some pics... The first is from above, looking down at the tensioner. the second is the area of the pin holding the far bottom of the tensioner, half drilled out. I got the front edge, but need to get the back edge... I'm gonna take the oil pan off and see what I can see. The pin is about as from the bottom as it is from the top.
ID:	1017410   Click image for larger version
post #5 of 9 (permalink) Old 07-01-2014, 06:27 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 480 Post(s)
maybe try a easy out and get it to spin some and then pull out?
thread the hole you drilled and put another bolt in?
rumb is offline
post #6 of 9 (permalink) Old 07-01-2014, 07:08 PM Thread Starter
Cheetahpop's Avatar
Vehicle: 1971 220D
Yeah, the fix is gonna have to be a bolt where that pin is now... To get the oil pan off, I need a long 5mm hex socket It'll be Thursday, probably when I can get to the hardware store. I've been twisting, pushing, pulling and banging. But it's still there. Thanks for the encouragement.
post #7 of 9 (permalink) Old 07-02-2014, 09:06 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
i would cut off the upper part of rail , so you can pull head off , then , you will be closer to the problem .
agillot is offline
post #8 of 9 (permalink) Old 07-02-2014, 03:27 PM Thread Starter
Cheetahpop's Avatar
Vehicle: 1971 220D
Yes, I have considered that... an obvious last resort. Thanks.
post #9 of 9 (permalink) Old 07-03-2014, 01:44 PM Thread Starter
Cheetahpop's Avatar
Vehicle: 1971 220D
DONE! After getting the oil pan off, it was easy to see the pin, and some work with a hacksaw blade did the job. Initial exam of the head gasket shows no cracks or warping. I will look at it in detail as I clean it. the block, however, has oil around the 4th cylinder -- as if it were seeping under the head gasket. So this may just be the gasket...
ID:	1020577   Click image for larger version
