Trying to renew from suspension - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-30-2014, 10:13 AM Thread Starter
Vehicle: 1972 280se 4.5
Trying to renew front suspension
I'm not sure this has been covered previously. I have a SE 4.5. It drives fairly well on smooth tarmac but groans and clonks on rough surfaces and on braking at low speeds.
Shocks are new, Bilstiens. I have no problems with alignment or brakes.
I think my bushes and ball joints are bad.
Is there a kit I could get to get it back to spec or does anyone what to replace by item and where to get it.
enjoymentman is offline
post #2 of 8 (permalink) Old 06-30-2014, 01:51 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
W108s don't have ball joints. They have king pins. King pin kits are available everywhere.
TZ_280SEL is offline
post #3 of 8 (permalink) Old 06-30-2014, 07:33 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
108 has 14 grease joints that require regular greasing,when neglected you get the dry bushing sounds
adler is offline
post #4 of 8 (permalink) Old 06-30-2014, 09:50 PM
Quoted: 59 Post(s)
108: The rear axle has two grease pins at the joint.
adler is offline
post #5 of 8 (permalink) Old 06-30-2014, 11:26 PM Thread Starter
king pins....hmmm.... thanks guys
post #6 of 8 (permalink) Old 07-01-2014, 07:35 AM
TZ_280SEL's Avatar
Quoted: 36 Post(s)
If they have not been regularly greased, they may be difficult the first time. As said above, 14 fittings on the front end. one on each control arm bushing (4/side), one at the top eccentric joint on each king pin. One at the bottom of each king pin, and one on each king pin itself.
My W108 had sat for many years so it took a bit of work for mine to take grease again. I removed each fitting and soaked them to ensure they would take new grease. I then had to soak each grease point with penetrating oil to loosen the old grease (sprayed through the fitting hole). Let that sit a few hours, put the fittings back in, try like heck to get them to take grease. If you do need to do the penetrating oil method, make sure you put plenty of grease through the first time to flush all the oil out.
At the end of the day, I salvaged the king pins, but had to put in new eccentric kits. Major PITA.
post #7 of 8 (permalink) Old 07-01-2014, 10:31 AM
Quoted: 59 Post(s)
Most grease brands are incompatable with each other so its best to stock one good brand and flush out the old grease in the joints.
adler is offline
post #8 of 8 (permalink) Old 07-01-2014, 01:01 PM Thread Starter
Wow! Thanks guys. I make go the new king Pins route.....
