Engine Replacement 250sl - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-27-2014, 03:35 PM Thread Starter
Date registered: Jun 2014
Vehicle: 2011 SLS AMG
Hey Guys,
The numbers on my 250sl pagoda dont match up. The engine number is that of a 280se. If i buy a replacement original 250sl engine then can I replace it outright or will this require me changing the gearbox or other components?
Also will Mercedes Classic centre be able to provide the engine?
Cheers in advance
ghost77 is offline
post #2 of 11 (permalink) Old 06-27-2014, 04:17 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
what is wrong with the engine in car now ??? classic center ?????? why .
agillot is offline
post #3 of 11 (permalink) Old 06-27-2014, 04:30 PM Thread Starter
its an engine from a 280se. i want to put a 250sl engine.
ghost77 is offline
post #4 of 11 (permalink) Old 06-27-2014, 08:01 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
Pl5ease go to sl-113.org. You will get the most help.
Baybear
Baybear is offline
post #5 of 11 (permalink) Old 06-28-2014, 04:59 AM Thread Starter
I've checked that out but I can't find a clear answer :/
ghost77 is offline
post #6 of 11 (permalink) Old 06-28-2014, 06:00 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1647 Post(s)
If it's not the original engine, does it matter what is in there? Are there any problems with the current engine?
Sent from AutoGuide.com App
My signature:
Click for list of my 33 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #7 of 11 (permalink) Old 06-28-2014, 07:04 AM Thread Starter
Wanted to atleast have a 250sl engine to maximise the value I can get out of it even if it isn't matching number
ghost77 is offline
post #8 of 11 (permalink) Old 06-28-2014, 08:26 AM
Fonzi's Avatar
I've been thinking about the junk cars I own, and consider I would probably be smart to dump everything but my convertible SLC, and replace them with a w113 stick shift. I think I would be willing to consider a modern drive train. That probably would not be the best for resale value, but I would imagine that it would maybe make for the best driver car. So if I was in your shoes, I might consider finding an an engine that could be rebuilt, or maybe buying the engine from Mercedes, but probably not even put it in the car. I would probably just store it until I wanted to sell the car. I'd probably want to put in a modern drive train if practical. But that's all moot if the car isn't driven too much.
I've never paid over $8000 for a MB. So it's a whole different ball game than the one I play in. I think I should try to up my game to a cheap w113 though. I assume it could be a smart move.
My signature:
Fonzi is offline
post #9 of 11 (permalink) Old 06-28-2014, 08:43 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
for some reason the 230 or 250 sl where never in big demand .[ a 71 280 sl on the other hand is ] since the original engine is no longer there , this car is probably worth more with this 280 se engine . the difference between a 280se and sl is the camshaft , the 280sl spins a little faster , 2 to 300 rpm ??? .
agillot is offline
post #10 of 11 (permalink) Old 06-28-2014, 04:05 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
Is your tacho an electric or mechanical drive? I know with W111 coupes, there can be problems with no mechanical drive for the tacho when using the later engines, and the head has to come off to fit the drive.
You would be best off discussing your options and their impact on value on 113.org as it is such a subjective thing. Personally, I am rebuilding a 280 motor and mating it to a floor shift manual to go into my 250 coupe rather than replacing the 250 and auto, as it is the highest output 'standard' motor and has a more desirable trans for a sporty drive. Most people on the sites I hang out on are more aroused at the prospect of this driveline than the standard 250 + auto. Would that translate to extra value come re-sale? Don't know, and don't care, as I am building it for me to drive.
As for engines, the CC will be expensive. Metric Motors has a good reputation, but again they are expensive. I doubt you would recoup the cost of those engines come time to sell, unless you are doing a nut and bolt resto to a super high standard. Note that I bought a finnie sedan that a guy had a resto shop rebuild the motor for - he spent $18k on the motor... he then blew it up and I bought the whole car for $2000.
Good luck, Drew
drew56cus is offline
