Steering Wheel Straight but Wheels Turned - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-24-2014, 08:01 AM Thread Starter
Date registered: Dec 2012
I changed the tie rods in my 77 280SE and did not have a chance to align the vehicle. But when the vehicle is parked with the steering wheel straight the wheels are turned to the right.
Any thoughts on what's wrong?
Thanks!
Dayminder is offline
post #2 of 6 (permalink) Old 06-24-2014, 08:14 AM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
The tracking will need to be set correctly on a 4 wheel tracker, the steering wheel will be locked in the straight ahead position, and the track rods adjust to give the correct toe for the car. As it stands you could be scrubbing off the tread and it could be difficult to keep the car on a straight line.
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #3 of 6 (permalink) Old 06-24-2014, 08:26 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
you cannot replace the tie rods and not align the car .
agillot is offline
post #4 of 6 (permalink) Old 06-25-2014, 05:27 AM
Pizing82's Avatar
Date registered: Jun 2013
This method will allow u to drive the car but will not guarantee it won't scrub tyres. Think like this, if the steering is to the right when the vehicle drives straight by straightening the wheel you turn the wheels left. Turn the rod ends evenly eg screw 1 side in 2 turns screw the other out 2 turns? If you do this on the garage floor drive the car after an adjustment and you'll figure out if you went the right way.
When you're close to straight run a tape from left to right on the front side of the tread and then do the same on the rear side of the steer tyre. You would want them the same ie 0.0mm toe. That will get you safely to the aligners.
Pizing82 is offline
post #5 of 6 (permalink) Old 06-25-2014, 06:04 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1652 Post(s)
True. Tierods normally command an alignment, at least if you care about your tires and MPG.
On many models, there is a line on the steering wheel bolt that is supposed to be vertical when the tires are straight. Sometimes the steering wheel just wasn't put on correctly.
Sent from AutoGuide.com App
My signature:
Click for list of my 33 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #6 of 6 (permalink) Old 06-25-2014, 01:12 PM
Date registered: Jan 2004
Quoted: 30 Post(s)
On your car there is also a bolt on the steering box that comes out and a special tool (pointed bolt) that goes in its place into a detent in the steering shaft to lock it in place during the alignment. That insures that the steering wheel is absolutely centered and remains so during the alignment process.
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 206,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 8700 miles
sokoloff is offline
