ac question 1973 280 sel - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 06-23-2014, 07:16 PM Thread Starter
KyBill's Avatar
Date registered: Feb 2014
Vehicle: 1973 280SEL 4.5
Quoted: 9 Post(s)
Recently had it in the shop to fix the ac. I thought it was going to be super expensive. They said it was just a loose wire. I tried to use the ac the other day, it it came on, blew cold, and then shut off abot 30 seconds later. It now won't come back on. Could it be a fuse, or the wire loose again? I had a similar issue with the dash lights. They said it was a fuse, the light worked fine, then went out the next day. Could it maybe be an irregular voltage issue or something like that? I'm trying to get better at fixing this car on my own, so any help is greatly appreciated!
KyBill is offline
post #2 of 25 (permalink) Old 06-24-2014, 07:35 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
does the fan shut off , or it just is not cold anymore ????
agillot is offline
post #3 of 25 (permalink) Old 06-24-2014, 10:05 AM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
It does nothing now. No fan or green light. Worked once after the shop for a few seconds, then shut off like someone flipped the switch off. It did blow cold for the brief time it was on.
KyBill is offline
post #4 of 25 (permalink) Old 06-24-2014, 02:10 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Blown fuse or other electrical connection interruption.
Grubeguy is offline
post #5 of 25 (permalink) Old 06-24-2014, 02:55 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
Or bad ground.
Scoot is offline
post #6 of 25 (permalink) Old 06-24-2014, 05:05 PM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Would I have to remove the dash to check the ground? I found the fuses, so I'll check those tomorrow. I can't find a manual, so I'm just not sure what is ac, and what is heat. I know they are two separate systems. Thanks for the suggestions.
KyBill is offline
post #7 of 25 (permalink) Old 06-24-2014, 06:40 PM
Scoot's Avatar
Quoted: 126 Post(s)
Post picture please. If it is under-dash KuhlMeister or equivalent I think that the ground is the unit itself screwed into the car. I thought for your model year they were not so separate though. On a 114/115 they are separate, but on a 108/109???
Scoot is offline
post #8 of 25 (permalink) Old 06-24-2014, 07:09 PM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Thanks, I'll post pics tomorrow. I appreciate the help!
I may be thinking of the wrong thing.I just know the mechanic mentioned the ac and heat had separate motors. I had the motor for the heater replaced because it was seized up, but they said ac one was fine.
KyBill is offline
post #9 of 25 (permalink) Old 06-24-2014, 08:46 PM
Scoot's Avatar
Quoted: 126 Post(s)
The mechanic is probably right. I'm not familiar with the later AC on W108 cars. The early ones that have Kuhlmeister like in a W111 don't have a separate ground wire - they just ground to the attachment points. But post a picture when you get a chance. Also, the fuse for the AC is possibly NOT in the fuse box but instead in a small 2-fuse fuse box near the firewall (like the radio fuse for example)
Scoot is offline
post #10 of 25 (permalink) Old 06-25-2014, 09:21 AM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Please let me know if I need to take more detailed pics of something.
ID:	1006202   Click image for larger version
ID:	1006210   Click image for larger version
ID:	1006218   Click image for larger version
ID:	1006226   Click image for larger version
KyBill is offline
