ac question 1973 280 sel - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 06-25-2014, 10:36 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 115 Post(s)
That unit has a blower as part of the under-dash unit, probably located to the right and back somewhere. So you get nothing when you turn the fan knob, right? On a 108 I'm thinking you have to have the HEATER temp levers to the cold position for the AC to go on - like there is a switch or something built into them to keep the AC from coming on if you have hot air running to the system. So make sure both of the heat temp levers are all the way in the cold (blue) direction. I think that is the lower two levers, towards the center as it appears in your photograph. I don't know if it cars about the position of the other levers, but I would assume that it wants the outside air coming in to be closed also. Which is again, I think towards the center.
I would check all the fuses under the hood - can't tell from the picture but do you have a few small exposed fuse boxes on the passenger side of the firewall? Make sure you are getting power to them. Short of that, I would say to make sure that the unit is grounded by adding a ground wire temporarily and see if the fan starts blowing.
Scoot is offline
post #12 of 25 (permalink) Old 06-25-2014, 10:57 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
On the W108 (I have a 72), the heater/defrost is completely separate from the AC unit. The AC unit has its own blower located in the passenger side footwell. It is controled by the two knobs on the AC unit (fan and temperature). The unit "maintains" temperature by cycling the compressor based on the temperature out of the evaporator.
Do you know where the loose wire was that your mechanic "fixed"? I would start there. If you are getting nothing (no light/fan/compressor), there are two possible issues; 1) there is a lack of power to the system meaning a fuse and/or wiring issue or 2) the switch that turns on the blower (and consequently the compressor) has failed. The green light tells you there is power to the clutch of the compressor so it will cycle on and off as the compressor cycles.
I have suffered through the failure of this switch. It is no longer available as far as I can tell. It is an infinitely adjustable blower speed switch with a single power input and two outputs. Both outputs are zero volts with the fan turned off. Turning the fan on turns on the blower and also provides power to the clutch circuit. As you continue to turn the blower switch, slide contacts adjust the voltage to the blower motor causing it to speed up/slow down, but the power output to the clutch circuit stays at 12V.
Since I was unable to find a new switch and I hate putting in "new" 42 year old used switches, I replaced mine with a switch meant for a 60s era mustang I believe. It is a 4 position switch so I now have OFF, HIGH, MEDIUM, and LOW for blower speed.
If your fuses are good, I would look at this switch.
TZ_280SEL is offline
post #13 of 25 (permalink) Old 06-25-2014, 05:45 PM Thread Starter
KyBill's Avatar
Date registered: Feb 2014
Vehicle: 1973 280SEL 4.5
Quoted: 9 Post(s)
All fuses but one tested ok (under hood & in driver side compartment). Replaced that one and the dash lights started working. According to the owners manual, fuses under the hood power ac. They tested fine, but looked rough. I replaced them all, still no luck. Is there a way to test the switch for the ac? I popped of the cover under the ac controls. Here are the pics of that
KyBill is offline
post #14 of 25 (permalink) Old 06-25-2014, 05:47 PM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Here are the pics.
ID:	1006849   Click image for larger version
KyBill is offline
post #15 of 25 (permalink) Old 06-25-2014, 05:48 PM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Also, not sure how to ad a ground wire.
KyBill is offline
post #16 of 25 (permalink) Old 06-25-2014, 05:52 PM
Scoot's Avatar
Quoted: 115 Post(s)
Well since the fan switch is exposed now the ground wire isn't important. Get a test probe, the kind that has an alligator clip on one end of a wire and a test light on the other with a probe and connect the alligator clip to something in the car that is grounded. That would be something metal that isn't painted, or in a Mercedes just about anything with a brown wire running to it. If your car has chrome door jam light switches, connecting the clip to that would be OK, or to something that is bare metal. Then (with the car turned on so that power should be running to the switch) touch the probe to each of the terminals on the switch. With the switch off you should get power going to one of the terminals. With the switch on you should be getting power going to more than one of the terminals.
Scoot is offline
post #17 of 25 (permalink) Old 06-26-2014, 05:07 PM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Switch off, I get power to one terminal. Switch on, still only power to one. If I turn it all the way, the light goes out on the tester for that terminal. Does this mean the switch is bad?
KyBill is offline
post #18 of 25 (permalink) Old 06-26-2014, 09:12 PM
TZ_280SEL's Avatar
Quoted: 36 Post(s)
If I remember correct, power comes in the center spade (looks to be orange from your photo). If you have power here but nothing on the other two ever, then my guess is switch is bad. You can test by jumping the hot to the other two with a piece of wire. One should turn on the fan and one should turn on the green light and energize the clutch (as long as temp is on cold setting).
When mine failed, I tried in vain to find a new one. I ended up with a straight 3 speed switch. I believe mine is from Nostalgic Air, part number 119-9910.
Mine is now off, low, medium, high. It has a clutch contact as well. $20 and it was plug n play.
post #19 of 25 (permalink) Old 06-26-2014, 09:33 PM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Thanks! I'll try a new switch. I didn't see the part number you listed on their site. Does this look like the part?
http://nostalgicac.com/binary-high-l...e-threads.html
KyBill is offline
post #20 of 25 (permalink) Old 06-27-2014, 06:49 AM
TZ_280SEL's Avatar
Quoted: 36 Post(s)
No. On their site, go to controls and motors; then ac blower switches; then it should be the resistor blower fan switch
