3.5 rear diff - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 06-23-2014, 07:43 AM Thread Starter
tewfiks's Avatar
Vehicle: Many MBZ, Couple of 911s, couple of pick ups
Quoted: 49 Post(s)
Post 3.5 rear diff
Hello,
Looking to change my rear differential on my 1970 280 SE convertible to a 3.5 rear differential. Do I need to source one out from a coupe or can I use one from a sedan?
Thanks
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
post #2 of 13 (permalink) Old 06-23-2014, 08:29 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
Same-same or to put it in the vernacular, no diff!
Mike D is online now
post #3 of 13 (permalink) Old 06-23-2014, 08:33 AM Thread Starter
tewfiks's Avatar
Quoted: 49 Post(s)
Post
Much thanks. Easier to source a sedan differential than trying to track down a coupe donor.
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
post #4 of 13 (permalink) Old 06-26-2014, 01:26 PM Thread Starter
tewfiks's Avatar
Quoted: 49 Post(s)
Post
Looking for a W111 or W109 rear diff.
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
post #5 of 13 (permalink) Old 06-26-2014, 08:04 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Are you looking for a particular ratio? A 3.5 coupe is 3.69 and a 280SE 3.5 is 3.46 and a 280SE 4.5 is 3.27
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #6 of 13 (permalink) Old 06-27-2014, 01:49 PM Thread Starter
tewfiks's Avatar
Quoted: 49 Post(s)
Post ratios
Just looking for my 1970 280 SE convertible to cruise at a lower rpm at highway speeds. Any suggestions?
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
post #7 of 13 (permalink) Old 07-01-2014, 12:45 PM Thread Starter
tewfiks's Avatar
Quoted: 49 Post(s)
Post
I have sourced a rear differential from a euro 6.3. Any issues that I should be aware of before proceeding?
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
post #8 of 13 (permalink) Old 07-01-2014, 03:39 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
If I remember correctly, the air suspension cars do not have the bosses that the horizontal compensating spring mounts to - can anyone confirm this? Many people talk about converting air suspension cars to steel springs - you need to find out what was involved in this. How have they achieved the mounting of the compensating spring?
drew56cus is offline
post #9 of 13 (permalink) Old 07-01-2014, 09:55 PM
Quoted: 8 Post(s)
if your car is a 6 cyl (or a V8) the 6.3 diff is going to be pretty tall+ it's not a bolt in (GGR here has some experience with 6.3 axles) I would go with the 3.27 from a 280SE 4.5-it will bolt right in and drop your 60MPH RPM to around 2600. The air suspension 6.3 did not have a compensating spring.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
3.5 Tony is offline
post #10 of 13 (permalink) Old 07-02-2014, 07:15 AM Thread Starter
tewfiks's Avatar
Quoted: 49 Post(s)
Post 4.5 Diff
That is good to know. A 4.5 differential will be easier to locate. Dropping the rpms at cruising speed is my goal.
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
