What is the best way to lock the crankshaft? Front main seal replacement. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-20-2014, 02:32 AM Thread Starter
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
I need to change the leaking front main seal. I have everything out that needs to be out, except for the large bolt that goes into the crankshaft.
What is the best/proper way to lock the crankshaft from turning so that I can try to remove the that main bolt?
Luna Gaudi's 72 250 is offline
post #2 of 4 (permalink) Old 06-20-2014, 06:30 AM
Date registered: Aug 2009
Quoted: 59 Post(s)
Easiest way is to use an impact (air or electric) wrench.
Mike D is offline
post #3 of 4 (permalink) Old 06-20-2014, 08:28 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
impact wrench for out and back in , if not hold the damper with a wise grip and it will hold against the water pump housing .
agillot is offline
post #4 of 4 (permalink) Old 06-20-2014, 03:42 PM Thread Starter
Quoted: 17 Post(s)
Thanks for the suggestions. My impact wrench is a standard size one, but it
would not fit because to the air conditioning radiator. The vise grip trick did
not work either. Here is what I came up with that worked really well.
A piece of 1/2" rebar positioned under the altenator bracket and the power
steering bracket. Then a steel tent hold down spike fitted through the
existing hole on the harmonic balancer. (I bent the spike so that it would
not hit the ac radiator, it was easier to bend it then to cut it) Then a large
breaker bar and a socket and i was able to get it off.
Now I am having trouble removing the harmonic balancer. I saturated with
penetrating oil and used a pully puller, and it didn't even budge. I think I
may need a larger puller.
Any suggestions would be welcomed.
