1973 450sl roadster automatic - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-18-2014, 11:32 PM Thread Starter
Date registered: Jul 2012
Vehicle: 1972 300sel 4.5 & 1973 450sl
recently i had some work done and I can only assume that the mechanic failed to refill/top off the trans fluid. About 300 miles later my gears were hard shifting. I checked the fluid, it was real low, it took 1/2 quart or 540ml to achieve the top line after all gears were lubricated. I checked for leaks and saw a drop, but never once a drop on the floor of my garage and those 300 miles combined were only two driving occasions over an elapsed time of 4 months. After proper fluid replacement, there is still a hard shift into and out of drive. Reverse has not changed so much and is mostly smooth. I am aware of the vacuum modulator, but I have been told of adjustments that I can make to the transmission to smooth or sharpen the shift, and that the modulator has something to do with it. I am mechanically inclined, but ever so scared to turn the first wrench, then usually I am fine. I'd hate to botch things up. I could really use some advice and i hope i didn't take my perfectly running 450sl and botch it up. thanks much
Hal Yeah is offline
post #2 of 2 (permalink) Old 06-19-2014, 05:06 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1571 Post(s)
It might be nice if a moderator could move this to the 107 forum.
Is it hard shift into Drive, and hard shifts between 1 and 2 and 2 and 3? Or is it just a hard thunk when shifting into drive?
Vacuum leaks increase the manifold pressure just like a wide open throttle would, which causes higher revs before shifts, and that makes shifts feel hard when you aren't accelerating quickly.
I fixed some vacuum leaks in my 73 450sl and was a little disappointed that the car didn't rev as high under full throttle as it had before. It was smooth as butter though, just not as sporty.
Sent from AutoGuide.com App
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
