W108 Steering Coupler - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 06-26-2014, 07:27 AM Thread Starter
craftysince86's Avatar
Date registered: Apr 2011
Vehicle: W211 | W108
sorry for the delay in response
i assume this will be the last steering coupler to go into this car, i found one a bit cheaper so i think i am just going with the OE
i did have another question though, when looking up the part on autohaus i see there is a separate bushing available. If i buy the complete coupler do i still need to purchase this bushing or will that all be included? i know there is two types of couplers, one where the bushing is built in and another where the bushings can be removed and swapped out.
the part number specific to my car is: 115 460 0510
just not sure how to tell the difference between the two different variations.
W211 '03 E320 | W108 '72 280SEL 4.5
craftysince86 is offline
post #12 of 19 (permalink) Old 06-26-2014, 11:34 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 93 Post(s)
Originally Posted by agillot View Post
I would use the cheap coupler on my own car , but not on a cust car .
Interesting take on the risk/benefit analysis,
ejboyd5 is offline
post #13 of 19 (permalink) Old 06-26-2014, 12:25 PM
tewfiks's Avatar
Vehicle: Many MBZ, Couple of 911s, couple of pick ups
Quoted: 50 Post(s)
Post
I did this job on my 1972 280 se 4.5 without issue. The part from autohaus was spot on like the OEM.
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
91 420SEL
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is online now
post #14 of 19 (permalink) Old 06-26-2014, 04:43 PM Thread Starter
did you buy the oem one or the other one?
post #15 of 19 (permalink) Old 06-29-2014, 11:33 AM
tewfiks's Avatar
Quoted: 50 Post(s)
Post
the other one
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
91 420SEL
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
post #16 of 19 (permalink) Old 06-29-2014, 02:03 PM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
Be usre to match your Vin # with the Autohouse part. The part fits a specific chassis. I bought one and had to return it because of this. My chassis is as early year model and it makes it somewhat difficult to find items like electric window regulators, couplers, etc
Kitaka is offline
post #17 of 19 (permalink) Old 06-29-2014, 02:10 PM Thread Starter
Yea I called the dealer and got my part # and then just searched the web and found it a little cheaper than autohaus.
I'm just not sure if I need to order seperate bushings for this or if it's just all built into the actual coupler.
post #18 of 19 (permalink) Old 06-29-2014, 03:30 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
there are 2 couplers , look identical, one is riveted together , the other come apart , has clips , around late 60 to early 70 went from hold fixable to new riveted .you can tell by looking on the car , and see if you see clips .if you do , you are lucky .
agillot is offline
post #19 of 19 (permalink) Old 06-29-2014, 05:31 PM Thread Starter
i have an early 70's sounds like i will be changing my whole coupler, but i will try and get a glimpse of when soon to try and verify.
