3.5 ignition coil - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 06-02-2014, 03:55 AM Thread Starter
Pizing82's Avatar
Date registered: Jun 2013
3.5 ignition coil
Hi guys, I just bought an igniter 1 setup to convert from points to elec ignition.
I was wanting to change the coil at the same time to take advantage of the setup.
Any advice what coil to run? I was thinking a flame thrower 2 but was unsure what ohms it needs to be?
I'm sure others have done this mod before. Anyone?
Pizing82 is offline
post #2 of 21 (permalink) Old 06-02-2014, 05:26 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 104 Post(s)
I've done the mod. Get the cheapest Flamethrower coil - the upgrade only adds 5,000 extra volts to the final spark and isn't necessarily worth the money.
Your car will run 1000% better with the new stuff, btw. A word to the wise (that wasn't me when I did it) - track what wires you take off and where they used to go, in case something doesn't work or leaves you stumped. That way, you can go back to original as a troubleshooting step.
Grubeguy is offline
post #3 of 21 (permalink) Old 06-02-2014, 05:32 AM Thread Starter
Pizing82's Avatar
What ohm coil did u run?
Pizing82 is offline
post #4 of 21 (permalink) Old 06-02-2014, 08:12 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
I also have the Pertronix ignition and coil. Per the Pertronix catalog (page 56), If you are running a 12 Volt system, then you need a 1.5 Ohm coil for 8 cylinder engines and 3 Ohm coil for 6 or 4 cyl.
TZ_280SEL is offline
post #5 of 21 (permalink) Old 06-03-2014, 04:15 AM Thread Starter
Pizing82's Avatar
Have to remove the resistor?? The coil has a built in resistor, is that correct?
Pizing82 is offline
post #6 of 21 (permalink) Old 06-03-2014, 07:04 AM
Date registered: Dec 2006
PerTronix (Hall Effect) Ignition for Mercedes-Benz Pontons © www.mbzponton.org
This page and guide by the late Randy Durrance helped me with installation...
jmela is offline
post #7 of 21 (permalink) Old 06-05-2014, 02:55 AM Thread Starter
Pizing82's Avatar
Hi, thanks so much for the link, very informative!!
Pizing82 is offline
post #8 of 21 (permalink) Old 06-06-2014, 11:15 PM Thread Starter
Pizing82's Avatar
My intention is to replace the points with elec ignition. Just for my own reasons I'd like to try get a decent tune on the point ign. The engine is popping through the exhaust every now and again. Unsure what could be causing it.
I removed the plugs for a look and they're pretty black.
I thought I'd check the timing and dwell timing is at 8deg advanced 34deg dwell. Premium fuel Ron 98. I'm thinkin she needs more timing not pinging and when you floor it she stutters and goes which tells me it could do with more timing.
Thoughts?
Pizing82 is offline
post #9 of 21 (permalink) Old 06-14-2014, 02:15 AM Thread Starter
Pizing82's Avatar
Well what I thought would happen did happen. Removed the points and fitted the module this was pretty easy. Removed the coil and replaced with flamethrower type and vehicle won't start. No spark. I think the prob is the coil wiring. I thought all I'd have to do is the pos wire that ran off the ballast resistor remove the whole resistor and connect the wire that fed the resistor and connect it straight to the pos on the coil. Then I noticed a second resistor ???? Pretty sure this is std setup but I'm unsure if the wiring is correct. With ign on the pos side of the coil has power but my test light is dim. I don't think the voltage is correct. Haven't got a multimeter either. 3.5 ignition coil-imageuploadedbyag-free1402737212.672322.jpg3.5 ignition coil-imageuploadedbyag-free1402737227.455285.jpg3.5 ignition coil-imageuploadedbyag-free1402737250.030133.jpg
This components are still in the pos circuit?
Advice/help
Pizing82 is offline
post #10 of 21 (permalink) Old 06-14-2014, 09:48 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
The ignitor red wire goes to + on coil as does the wire with +12v on it. No resistor in between +12v and coil..
if you still have the resistor connected at +12v point engine will miss!
adler is offline
