Getting into the Trunk (77 280SE) - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-01-2014, 03:57 PM Thread Starter
Date registered: Dec 2012
Does anyone know how to get into the trunk? The ignition key does not work and if there is a trunk key I never had that.
I tried to get there through the back seats but I could not get that to work.
PB Blaster etc does not work.
Dayminder is offline
post #2 of 6 (permalink) Old 06-16-2014, 01:26 PM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 194 Post(s)
you might be able to open gas flap push small metal locking rod out of the way then remove gromet and with a small hook tool reach in and grab the vac line and pull through hole and then supply pressure to hose sometimes will unlock trunk lock. lock system works off vacumm but i have put air pressure to make it work backwards. you can try this from driver door switch also. we have used gas flap line when locked out of car
current stable
2010 glk350-86 300e-88 300e white-88 300e blue-66 220seb-74 230-89 560sec white-91 560sec taupe?-92 300te-83 380se parts car- 2012 chevy cruze eco wifes commutor 40plus mpg on regular. 1970 gmc 2500- 2002 gmc 2500hd duramax/allison-50s something willeys pickup- 74 scout-88 jetta karat-74 harley fxe-92 harley flhtcu ultra classic-95 harley road king-96 harley fatboy-98 special construction harley powered.- 2011 klx250 and to many off road vehicles and coming soon 69 280sl
1mbzdoc is offline
post #3 of 6 (permalink) Old 06-16-2014, 05:31 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Any good automotive locksmiths in your area?
flyboyike is offline
post #4 of 6 (permalink) Old 06-16-2014, 05:41 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1755 Post(s)
Neat trick in post #2.
But it sounds to me like this is a situation of the only key to the car being the valet key.
Why not send proof of ownership to the classic center and get the datacard key-code, and then order a key from the dealership.
I have also heard that the valet key is just a thicker key, and could potentially be ground down to a narrower key that could work all locks.
Does your key work the glove box?
Note:
Nearly all my information comes from experience with the 107 model.
Sent from AutoGuide.com App
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #5 of 6 (permalink) Old 06-17-2014, 07:48 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
does the ignition key work the doors , if not you have a different key for ignition due to a replacement of the tumbler with a generic one .[ common ] if key work the doors , but the trunk wont turn , soak trunk key hole with wd40 . if you have no keys for doors , get one from dealer [ cheap ]
agillot is offline
post #6 of 6 (permalink) Old 06-17-2014, 08:27 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
1977 is a single-key car (except for valet key if you have that).
I agree with what earlier poster said. You are likely trying to stick a valet key into the trunk. Regardless, get the key code and order the key for the car. It should fit all of the locks, but if it doesn't fit ONE thing, it would most likely be the ignition that it would not fit as that is probably the one that has been changed. Cheap and easy solution.
Scoot is offline
