Overheating starter? - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 06-17-2014, 05:44 PM
Date registered: Aug 2009
Quoted: 60 Post(s)
If it is an automatic transmission the neutral safety switch could be the culprit. If it happens again try putting the shift lever into the "neutral" position.
Mike D is online now
post #12 of 16 (permalink) Old 06-17-2014, 05:59 PM Thread Starter
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
I tried the neutral thing when the car wouldn't start... no joy
Grubeguy is offline
post #13 of 16 (permalink) Old 06-17-2014, 07:46 PM
Date registered: Sep 2012
Vehicle: 1988 300ce 1973 280sel 1995 E420 1998 E320
Quoted: 43 Post(s)
Originally Posted by Grubeguy View Post
WTH? I drove for about a half hour and stopped. When I went to restart the engine, the starter seemed as if it wasn't there at all. All I could hear was the fuel relay click and NOTHING else. After a half hour or so, the starter came back without any issue what so ever.
The engine runs normally, all other electrical devices operate normally, the battery is nicely charged, etc etc. I've never known a starter to not operate when the engine hits full temp...
I plan to crawl under my beast, remove every connection on the starter, clean them and reinstall tightly.
I'd be curious if this is something anyone else has seen...
I had a similar problem with a 240D I had. It was the starter.
knapster is offline
post #14 of 16 (permalink) Old 06-21-2014, 05:05 PM
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
It was the connector at wire joint,cut and installed a new connector.
adler is offline
post #15 of 16 (permalink) Old 06-22-2014, 03:33 AM Thread Starter
Grubeguy's Avatar
Quoted: 102 Post(s)
The mechanic said I had a bad battery (bullshit). The car stranded me again and after taking the gear shift through all the gears and back to park, it started. I think I found the culprit.
Grubeguy is offline
post #16 of 16 (permalink) Old 06-22-2014, 06:48 AM
Quoted: 60 Post(s)
If this is on your '73 and its a late year date (manufactured after October or so) another possibility is the seat belt safety system. It is a relay which doesn't allow the power to flow to the solenoid if the seat belt sensor isn't engaged. It was only used one year which was late '73 though mid '74. Its located by the park brake mechanism under the dash.
I had this on my '74 W114 and it drove me bonkers. It would occur at random times with no way to predict it. Doing the neutral to park shift trick worked most of the time but not always. Pulling apart and cleaning the relay did the trick but I ended up by-passing the relay to remove it from the system.
